Author Subject: Replacement Clutch Release Fork
justsamo
Hello everyone, I was just looking for some advice regarding the above.
Half way through changing the clutch and all the associated parts, I've mullared the clutch arm
and bushes but i bought a replacement clutch release fork and arm from GSF.
Under inspection the new arm and bushes are completely different to the old ones despite being listed as the replacement under my reg number!
Any ideas?
Posted 17th Jan 2016 at 11:13
pictures will explain all.
Posted 17th Jan 2016 at 11:30
justsamo
Okay no worries, I'll pop down the garage in a bit and take some photos. Cheers.
Posted 17th Jan 2016 at 13:26
justsamo
Cant seem to upload any pictures.. Do they have to be under 8kb like display pictures?
Difficult to do as this is being done on my phone/iPad...
Posted 17th Jan 2016 at 17:09
host them elsewhere and paste the link
if the shaft is smaller diameter then its not the right one.
you need a pull type for a be3 box? sounds like its an ma item.
Posted 17th Jan 2016 at 17:17
justsamo
Here we go...
justsamo has attached the following image:
Posted 17th Jan 2016 at 17:56
Yep, completely incorrect. Yes
What exactly is the issue with using the original fork? You would obviously require new bushes for it.
Posted 17th Jan 2016 at 18:17
justsamo
Nothing wrong I just thought to buy and replace everything.. I think the other bushes and stuff fit the old fork.. Reckon that'd be okay?
Posted 17th Jan 2016 at 20:58
6waysforward
Bushes are only a few quid from the main dealers. Clean up the fork ends, copper slip the bushes and job jobbed Thumbs up
Posted 17th Jan 2016 at 22:15
justsamo
Okay so I can use the new arm
But get some genuine bushes and pin yeah?
Posted 17th Jan 2016 at 22:23
6waysforward
No. Its clearly very different and not long enough.
Use the original black arm, get some new bushes from peugeot.
Posted 17th Jan 2016 at 22:32
Don't use copper grease as this will wear out bushes use normal grease Thumbs up
Posted 17th Jan 2016 at 22:38
yeah, what the rat said.
Posted 17th Jan 2016 at 22:51
justsamo
Yeah the black fork but the arm as shown in the picture! Will get some new bushes and use normal grease. Thankyou all! Hoping all this time I've spent on this chuffing clutch will be worth it!
Posted 17th Jan 2016 at 22:57
Also buy a new clutch cable and then you'll see a massive difference between old and new stuff
Posted 17th Jan 2016 at 23:30
justsamo
Oh yeah got that covered! Everything down to a genuine sump plug!
Thanks again.
Posted 17th Jan 2016 at 23:34
Yes, the arm looks to be the correct part. Yes
Just need the new bushes for the fork from Pug and you should be good to go. Smile
Posted 18th Jan 2016 at 11:06
nope, wrong arm
Posted 18th Jan 2016 at 11:24
Was going to say... copper grease is an anti seize compound not a lubricant. Shouldn't be used on moving parts as it has copper particles in which are abrasive use normal grease to lubricate. No point changing the arm unless it's bent or damaged just clean up the ends replace the bushes and lubricate it well.
And the cable is what makes them stiff and heavy usually as it does two 90 degree bends on a right hand drive car so the cable wears Into the outer sheath as it attempts to straighten itself under load.
Posted 18th Jan 2016 at 13:51
the pressure plate springs age too.
Posted 18th Jan 2016 at 14:09
nope, wrong arm
It looks very similar, you're probably best off getting a genuine arm if your current one is mullered.
Posted 18th Jan 2016 at 14:42
justsamo
That arm is almost identical to the old one, even so I'll pop down to vospers. (Yay)
New bushes and an arm. The pennies are adding up.
Posted 18th Jan 2016 at 15:16
6waysforward
Yep my mistake, normal grease. I used bike bearing stuff, teflon rings a bell but its slippy so it should be ok Yes
Posted 18th Jan 2016 at 16:53
Welcome to GTI-6 ownership
Posted 18th Jan 2016 at 19:12
That they do sold my ex a Dturbo years ago and she knew the clutch was heavy but the cable eventually snapped. Then she had the cable replaced which snapped again shortly after LOL springs had gotten too stiff for the cable to handle.
Posted 19th Jan 2016 at 08:02
