Author Subject: Anyone on here good with Transits?!
martinh
As per title, I've recently got a 2001 mwb transit with the 2.4 90 bhp turbo diesel lump, (RWD).
On the test drive and drive home (about 10 miles) was perfect, was then parked up for about 2-3 weeks and since then it is massively down on power.
Started investigating and the air filter was soaking wet and bits of it had gone into the turbo, took the turbo off removed the bits of air filter and cleaned the turbo out, the blades on the turbo don't appear bent as when it's running it looks fine and doesn't make a racket, have also changed the fuel filter and had the fault codes read and nothing came up.
Anybody ever had a similar problem?
Posted 15th Jan 2016 at 18:55
check the intercooler and the rest of the pipework.
also have a look at the live data on the diagnostic stuff, compare to the expected values.
Posted 15th Jan 2016 at 19:26
mocinim
Check the diesel quality if its old and collapsing it will give you a loss in power
If its been sitting for long periods diesel can grow bacteria diesel bug !! Try draining the tank put some fresh v power diesel in tis good stuff
New filter wont make a difference is the fuel is degraded Smile
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 16th Jan 2016 at 19:59
Check the oil cap. If it's milky, someone's probably thrown one of these in.
  • Posted 16th Jan 2016 at 20:06
    mocinim
    That wont help his bifidus digestiveum
    Posted 16th Jan 2016 at 20:46
    maybe
    Has it got an EGR? My 2005 110hp use to either cut out randomly or loose power.
    Posted 17th Jan 2016 at 19:48
