Author Subject: Piper 270H dyno
Anyone else had their otherwise standard car dyno'd running 270H please?
Did mine today. Very impressed by the torque and power curves except a bit of a fuelling hole at 3.5k rpm. I was wondering if its a cam-specific issue or something up with my car. Fuelling otherwise is perfect Dunno
Posted 9th Jan 2016 at 20:31
Yes I got 186 bhp Wink
Posted 9th Jan 2016 at 20:39
You're so cool I wish I was your slipper so you could wear me when you get homeLove
Posted 9th Jan 2016 at 20:44
demondriverdan
They did well in my race engine, 203. That was with 45mm Omex bodies, Longman's ported and polished head, and 4-2-1 Maniflow manifold though!
Interesting they worked so well on a standard engine, maybe I need bigger cams
Rallye Race Car
Posted 9th Jan 2016 at 20:48
They drive very well on standard management, but then it does run a lot of fuel top end as standard.
But they do fit with standard pistons (timed right) so yeah you could go for something a lot bigger. Might lose a touch of driveability under 3k rpm though, but I guess you aren't too woried about that.
Posted 9th Jan 2016 at 20:55
Well wrap your legs around my neck and I'll wear you like the crown that you are Wink
They're great numbers and not to far away from the pt 81's/chip wizards remapped black rallye
Posted 9th Jan 2016 at 20:57
Only numbers...
Posted 9th Jan 2016 at 21:01
Numbers are fun! E numbers are even better! Hyper
Posted 9th Jan 2016 at 21:11
demondriverdan
If it's under 3k I'm in the pitlane Smile I've got pocketed pistons so have some scope for more lift. Need to learn how to time aftermarket cams, that's the only thing that puts me off.
Rallye Race Car
Posted 9th Jan 2016 at 21:35
barrym
Never had mine on a dyno but running Richard Longman 270 cams. When I got the car had a MASSIVE flat spot between 3 and 4K. Thought it must be retarded cam timing or something.
But swapped the open air filter for a BMC (slight improvement), replaced the MOT failure cat and lambda sensor (another slight improvement) and then changed the cambelt, water pump and crank pulley. Bingo, flat spot gone.
Would not have thought it should make any difference but it did?
Black Rallye occassional toy
Posted 9th Jan 2016 at 21:36
IvayloPavlov
At the Flywheel? With standard managment and manifolds?
Posted 9th Jan 2016 at 22:38
He's talking bo***cks...
Posted 9th Jan 2016 at 22:57
Corrected to 185.5bhp and 160lbft. No before though so who knows?
Doing a run before cocking about with bike bodies and a piggyback ecu
Posted 9th Jan 2016 at 23:00
hmm,.so mine had to be 200+ if it kept up whilst being heavier and longer geared
Posted 9th Jan 2016 at 23:16
You had all your tools on board too.
Posted 9th Jan 2016 at 23:33
Cheese board and wire cutter?
Posted 9th Jan 2016 at 23:55
Laugh my ass off
Posted 9th Jan 2016 at 23:59
