Any help much appreciated has I don't want to have this issue again many thanks Chris
displaying posts 1 to 25 of 34
| Author | Subject: Car won't start |
Cjwatson27
So I left my car unlocked whilst I was loading stuff into the boot, then it won't start locked it unlocked it nothing then after 10 mins it started straight away. Recently the remote central locking stopped working I've changed the battery but nothing.Any help much appreciated has I don't want to have this issue again many thanks Chris ________________________________________ Old pugs don't die they just get faster |
ben01328
Regular Location: Fakenham Registered: 10 Feb 2015 Posts: 115 Status: Offline |
could it be the immobilizer chip in the key, Ive got 3 keys 2 of which will unlock my car but wont start it, only discover this when i was swapping cases round as the keying bit broke on one. had to swap the chip as well and it worked straight away.________________________________________ Team Boosted![]() Team 330mm |
Seasoned Pro Location: Skelmersdale Registered: 07 Apr 2004 Posts: 2,769 Status: Offline |
Get a key copied at Timpsons, remove the new chip and put into your old key fob________________________________________ S Reg Diablo standardsSpec SORNEDR Reg Nile standard spec written off then repaired X Reg Astor in need of TLC R Reg Nile to restore Set of Lions to fit. |
Cjwatson27
Only got the one key , all of my wheel arch liners missing now would the alarm getting wet have anything to do with it ________________________________________ Old pugs don't die they just get faster |
Doesn't help when those things get wet best unplug it |
Cjwatson27
Can I just unplug it and throw it away ? Or will it cause me problem ? ________________________________________ Old pugs don't die they just get faster |
Cjwatson27
It's done it again starting fine all week took it down the road parked it up and nowt it's making all the right clicking noises just not turning over, the alarm is already unplugged 😒________________________________________ Old pugs don't die they just get faster |
Cjwatson27
The fuel pump relays is clicking and you can hear the pump priming, could this be something to do with the starter motor ? ________________________________________ Old pugs don't die they just get faster |
matt16v
Regular Location: SE Registered: 24 Jul 2011 Posts: 217 Status: Offline |
Check the fuse for the alarm siren, IIRC the immobilizer is on the same circuit.Phase 2 fusebox - http://www.306gti6.com/forum/showthread.php?id=69121 Phase 3 fusebox - http://www.306gti6.com/forum/showthread.php?id=67123 Fuse 6 on a PH3 IIRC ________________________________________ 1999 Astor Grey GTi-6 OEM+ |
Cjwatson27
It's been recovered now 😒 Does the imboliser disable the starter motor I always though it did the fuel pump ? ________________________________________ Old pugs don't die they just get faster |
robthe6
Senior User Location: northamptonshire Registered: 06 Jun 2008 Posts: 667 Status: Offline |
sounds like loose battery or starter terminals. had a very similar problem where it would work for a while then stop the start turning over but everything else worked. then it would all of a sudden start. ________________________________________ 1997 ph1 bianca GTI6 - The looker1996 ph1 Sigma GTI6 - Dead ![]() 1999 Red Rallye - The Daily 2005 Nissan Navara D40 - Family car 1968 Mustang Coupe - The dirty little secret Put ya foot down, put ya foot down we'll loose em easy! |
Cjwatson27
It's in the garage now and I've got a horrible feeling I'm about to get my pants pulled down. I though it could be a loose terminal but for the life of me I couldn't remember where the starter motor is all even see it ________________________________________ Old pugs don't die they just get faster |
Starter motor is under the inlet manifold |
Cjwatson27
Ahh I wonder if this is from the smash on the front ? Maybe it's loosened the wiring________________________________________ Old pugs don't die they just get faster |
I'd deffo say it's a wiring issue rather than a starter motor issue.What work was done after the bump? |
Cjwatson27
Umm I used a claw hammer to pry the bonnet open and presumed the rest would fix it self, for some reason I thought the starter motor was around the back of the block ________________________________________ Old pugs don't die they just get faster |
Cjwatson27 wrote: Umm I used a claw hammer to pry the bonnet open and presumed the rest would fix it self, for some reason I thought the starter motor was around the back of the block The only thing you could have damaged I'd say is the fan relays if you pryed the bonnet open from the fromt |
Chr1sch
Seasoned Pro Location: Worcester Registered: 02 Aug 2014 Posts: 1,025 Status: Offline |
Mine did exactly this but it didn't start again, turned out to be a fuse for the immobiliser |
Cjwatson27
Ok so the imboliser stops the starter motor then ?________________________________________ Old pugs don't die they just get faster |
Chr1sch
It was a little while back now tbh so can't remember exactly but from memory it was dead as a dodo but I think I could smell fuel, and from my limited understanding the immobiliser cuts ignition? (Sorry it was ages ago now so it's hard to recall exactly) |
jimmyhackers
Seasoned Pro Location: birmingham Registered: 14 Jun 2011 Posts: 1,302 Status: Offline |
i had something similar.....my friend was faffing about in the back of my car with the seats up.the dingle managed to unplugg the massive earth plug in the middle between the seats. completely deaded the car. payed 30 quid to get it towed home to find all i needed to do was plug the plug back in :S ________________________________________ the world is changed by people in sheds |
jimmyhackers
also..... i threw away my alarm box becasue its batteries were dead.for some reason it stopped the remote part of my central locking working, and nothing else :S best to unplug (but dont remove yet) yours seeif it does the same as what mine did ________________________________________ the world is changed by people in sheds |
Cjwatson27
Ok I'll wait to see what the garage says, would make sense I was moving flats so had a load of crap on the back seats ________________________________________ Old pugs don't die they just get faster |
robthe6
Cj if they cant figure it out. let me know an ill pop down an take alook at it. im only in brackley________________________________________ 1997 ph1 bianca GTI6 - The looker1996 ph1 Sigma GTI6 - Dead ![]() 1999 Red Rallye - The Daily 2005 Nissan Navara D40 - Family car 1968 Mustang Coupe - The dirty little secret Put ya foot down, put ya foot down we'll loose em easy! |
Cjwatson27
£360 for recovery 3 miles down the road from where there based and a new starter motor. Yep that sounds reasonable :-(________________________________________ Old pugs don't die they just get faster |
