Author Subject: uprated cams and valve springs NO LONGER REQUIRED
Twangy
after some uprated cams and valve springs to suit , if any about
wayne mcardle
Posted 29th Dec 2015 at 16:37
Twangy
bump
wayne mcardle
Posted 26th Nov 2015 at 11:43
eddy_gti6
Pretty sure pete_rallye has a couple sets for sale. Try dropping him a PM
Posted 26th Nov 2015 at 12:06
my mate dan clarke has some catcam 4903110 with the springs and retainers for sale.hes looking for 450 posted
contact me if you want his telephone number Thumbs up
Posted 27th Nov 2015 at 16:59
Twangy
dont want to go down the forged pistons and rods route yet , dont mind pocketing my pistons ,but will consider going wild cams when engine needs complete rebuild
wayne mcardle
Posted 3rd Dec 2015 at 18:33
pete_rallye
I've got some Piper 285h, and a set of uprated (but not piper) springs, although to be honest I would run them with standard springs quite happily.
Lap of the 'ring
Posted 3rd Dec 2015 at 21:15
Twangy
pm sent
wayne mcardle
Posted 3rd Dec 2015 at 23:11
demondriverdan
285s will need more than just pocketed pistons I thought?
Rallye Race Car
Posted 4th Dec 2015 at 10:06
1.85mm so quite marginal, certainly would be running a 1.4mm gasket.
Posted 4th Dec 2015 at 10:56
demondriverdan
Interesting, I thought you'd need more. How far can you safely go with pocketed pistons and a standard gasket? I've got 260s at the moment as they came up cheap when I was building the engine
Rallye Race Car
Posted 4th Dec 2015 at 11:52
Bridgecraft say +1mm on the valve cutouts, 1-1.5 mm is the safe clearance range, ive seen heavily skimmed heads touch with std piston at 1.4 mm.
so fat gasket, +1mm piston cutout and 1.85mm lift, might be ok as long as you dont sit at 7.5k+ for too long and get valve float from pumped up tappets
Posted 4th Dec 2015 at 12:19
blandy
So I'm guessing the 1mm deep cut outs doesn't equate to another mm worth of lift clearance then? Been reading up on your other clearance thread very informative
Posted 4th Dec 2015 at 12:24
