Author Subject: tie rods
mocinim
Hi gents looking for some info on tie rod replacement i believe you need a certain tool to remove and replace have looked in faq but can only find tie rod ends any info is welcome cheers Smile
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 21st Oct 2015 at 09:04
cully
tie rod ??
do you mean steering rack drum sticks?
Posted 21st Oct 2015 at 10:15
mocinim
I believe thats them inner tie rods
Posted 21st Oct 2015 at 11:19
mocinim
mocinim has attached the following image:
Posted 21st Oct 2015 at 11:21
mocinim
Its ok though have found the way any tips would be helpful cheers cully
Posted 21st Oct 2015 at 11:23
tvrfan007
Mole grips is all you need. There are access holes in the subframe. Not a difficult job really.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 27th Oct 2015 at 15:23
mocinim
Cheers tvrfan am wainting on new boots and managed to source oe peugeot clamps / clips will attempt this weekend cheers again
Posted 27th Oct 2015 at 17:51
stilsons
  • Posted 27th Oct 2015 at 18:41
    mocinim
    dangti6 wrote:
    stilsons
    Gone all special tool bout the place have been lent one will let you know if its any good failing that grips will do what ever fits best
    had a new rack in jan so shouldn't be to bad
    Cheers for the info guys not been in there before myself so here goes
    Posted 27th Oct 2015 at 19:37
    Looks like something you'd attach to a bicycle handle bar to clip a light to LOL
    I've got one of these I use for Clios but it's too small for 306s.
    dangti6 has attached the following image:
  • Posted 27th Oct 2015 at 20:58
    mocinim
    Looked at these on ebay you can get one with interchangeable head end pieces for around 30 buck but i guess unless you have many to do uts not worth the cost
    And yes it does look like a bike light clamp but if it works a Smile
    Posted 27th Oct 2015 at 21:30
    shabusta
    As said before use mole grips, i used a plumbers wrench (pipe wrench) for mine.
    shabusta has attached the following image:
    Posted 27th Oct 2015 at 22:09
