Author Subject: knocking from my front end
mocinim
Hi guys i have a knocking coming from my front right hub assembly or suspension
All runs fine no noises till breaking then i get a substantial knock from the front as the brake releases have just replaced the front shock and spring and drop link
Would this be likely that i have damaged the ball joint didnt disconnect it when fitting just compressed the old spring in situe to remove then jacked under it to wiggle in the new strut it seems solid as does everything else bit stumped
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 13th Oct 2015 at 09:23
Check the tightness of the bolts holding the caliper to the hub assembly.
  • Posted 13th Oct 2015 at 09:39
    Chr1sch
    i have a similar knock - driving me insane
    Posted 13th Oct 2015 at 10:23
    mocinim
    Could well be the caliper was giving it a good old wiggle when installing the shock will check tonight any other possibilities
    Posted 13th Oct 2015 at 12:17
    mocinim
    Ok so got back in there tightened everything up pushed everything passed the suggested torque Sad problem still there so got to the topmount and tightened everything including the strut bolt made it all much quiter thought sod it ill go for a small drive 30 yards down tested the brakes !small ! Click gently drove on testing the brakes noise then dissapeared all together
    Think it was mostly s**t on the brake pads will replace them next when i get to the drive shafts
    Bloody s**tty brake pads
    Where do you get subframe mount bushes if thats what there called (bbetween subframe and chassie)
    Cheers for the replies guys
    Posted 13th Oct 2015 at 18:55
