displaying posts 26 to 43 of 43
Pages (2): 1 [2]
Author Subject: Fuel pump query
other end of the black wire yeah
Posted 25th Sep 2015 at 09:42
I wouldn't bother yet, checking for spark is far easier, no spark = either ecu isn't getting power or its locked, and lastly, CPS, rare they fail.
Posted 25th Sep 2015 at 10:51
orta
So got sum new spark plugs, still no spark. Tried testing this crank sensor thing, which I assume is the connectors inside that brown plug in the picture and it's not giving me any resistance.
So does this mean it's now my crank sensor as well as my fuel pump and spark plugs... Oh and my fuel pump relay. All of which worked one evening and then the next morning decided not to. Stupid car only needed to keep working until the end of September before being sorned.
CLUB BLACK RALLYE
||B8s||60-70mm drop||Black Partner Steels||P1 VTS Rack||Refurbed Beam||Hybrid ARB||VTS Torsion Bar||
Posted 25th Sep 2015 at 17:36
if could be your ECU of crank sensor. one of them will stop the plugs sparking. this does not mean the plugs are knackered..
Posted 25th Sep 2015 at 18:28
mocinim
Why is it getting sorn in september
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 25th Sep 2015 at 18:40
plugs are rarely knackered.
Posted 25th Sep 2015 at 18:47
orta
Well I'm getting no resistance from the crank sensor (if testing the connectors inside the brown plug is the way u get it) so could be that?
CLUB BLACK RALLYE
Posted 26th Sep 2015 at 08:17
orta
It hibernates in winter
CLUB BLACK RALLYE
Posted 26th Sep 2015 at 08:18
Ben_W
Formerly gpm
Tom, I'd try replacing the crank sensor. Relatively cheap and that will stop the plugs firing.
No resistance is a fairly decent indicator....
Posted 26th Sep 2015 at 08:50
orta
Post #35
Yeah going to. Just gutted I couldn't do it in time for the expo tomorrow. I seem to miss this show every year...
CLUB BLACK RALLYE
Posted 26th Sep 2015 at 22:26
Post #36
Think of it as a blessing in disguise.
  • Posted 26th Sep 2015 at 22:28
    orta
    Post #37
    Is there a guide anywhere on changing the crank sensor? I couldn't figure out how to get mine off so when I tested it I tested it awkwardly in situ?
    CLUB BLACK RALLYE
    Posted 1st Oct 2015 at 20:30
    Post #38
    you just unbolt it and pull it out
    Posted 1st Oct 2015 at 20:41
    orta
    Post #39
    Yeah issue is its loose but the bolt won't come off and I can't get a spanner to it where it is... I was hoping there was a proper way to get to it?
    CLUB BLACK RALLYE
    Posted 1st Oct 2015 at 21:06
    Post #40
    From above.
    Do you have a socket set?
  • Posted 1st Oct 2015 at 21:30
    orta
    Post #41
    What's left of one so its a bit hit and miss. But from what I've found my crank sensor is attached to the frame with a bolt and nut underneath ?
    CLUB BLACK RALLYE
    Posted 1st Oct 2015 at 22:11
    Post #42
    google "gti6 crank sensor" to see what it looks like. it's just a 10mm bolt holding it into the gearbox casing and it lifts out. you're probably on about the brown plug being clipped onto something to keep it away from the gearbox. probably just slides off the clip
    Posted 1st Oct 2015 at 22:40
    orta
    Post #43
    It lives!!! f**king sensor!!! Now my tax has run out... :-(
    CLUB BLACK RALLYE
    Posted 2nd Oct 2015 at 14:05
    Pages (2): 1 [2]
