Author Subject: High coolant temp readings
barrym
Hi all, after some more of your technical expertise.
Today on my way to work I encountered some traffic and after a couple of minutes as I always do glanced at the coolant temp gauge. You can imaging my surprise to find it not at the expected 85-90 but somewhere around where 140 would be if the gauge read that far. Cue initial panic!
A few seconds of thought later and I looked at my oil temp gauge and saw it was at it's normal 90, so calmed down a bit and tried to think things through.
First thoughts were that no way should it read that high and the engine still run normally. I know my car and when it gets really hot, ie. the fans have come on 5-6 times in succession without remorse the car starts to hunt slightly and throttle response is a little wooly. There was none of this behaviour.
Also the rad fan had not kicked in to this point
Also, I believed, and this is where I may be wrong, the engine STOP light should have come on way before as a warning? Am I right in this or is the blue temp sender a 2 pin jobbie as it serves gauge and STOP light?
Anyway checked coolant, re-bled system (all 3 bleed points) etc and all fine, gauge seemed to function correctly from cold but quickly went into overdrive. Thermostat opened at indicated 90, Fans came on at indicated 110 but my feel was that the engine just was not as hot as that reading. Drove car home after work absolutely s**tting myself and stopping frequently to check everything.
Checked car again after cooling down at home and gauge reads 140 when cold.
I think, and have ordered a new blue temp sensor and expect it to solve this.
My question is - does that sound right to you? Especially my logic about the STOP light?
I plan to drive it to work tomorrow too. Obviously not ideal but I'm as sure as I can be there is nothing wrong with the engine or coolant syatem
BTW it's a non A/C Rallye
I know that's a long read but thought it best to give all the info first off
Barry
Black Rallye occassional toy
Posted 1st Sep 2015 at 20:08
ad
I have a very similar issue with a phase 3 at the minute and I am putting it down to head gasket going. I was also sitting in traffic and noticed my temp gauge rising, I got moving again and it still climbed up into the red which is when the stop light came on and I pulled over. I let it cool down, then had to fill her up with water (luckily I stopped in a village hall that had people doing yoga in) and bleed it all.
Managed to get home as I was about 30 miles away and that was that. It will only do a short journey now before it starts overheating so it's off the road now and will be sold as spares or repair as i have a phase 1 to take care of instead now.
But the answer to the stop light coming on is "only when it hits the red"
Posted 1st Sep 2015 at 20:26
barrym
Thanks for the reply mate.
Mu initial suspicion was indeed head gasket. Now I am pretty sure, or at least hopeful it isn't that.
Mine has used no water and doesn't just hit the red, it goes straight past it and out the other side, all without the fans coming on.
As I said above even when almost cold to the touch the gauge still reads well past the red, and the stop light hasn't come on. Is the stop light controlled, as I thought, by the green sensor?
Posted 1st Sep 2015 at 20:34
6waysforward
To be honest it sounds like the temp sender unit is playing silly buggers or the clocks are playing up.
Replace the blue temp sensor as you have ordered it now anyways and try it again.
I have a spare green and brown sensor somewhere and also spare clocks you can borrow to try and see if they help if the problem persists.
But the fan would be on if the water temp was that high which leads me to think its the temp sensor.
Posted 1st Sep 2015 at 20:37
stop light is one pin of the blue sender, temp gauge is the other one.
green is purely ecu, brown is AC models only.
non ac model fans are controlled by three pin thermoswitch under the top hose.
Posted 1st Sep 2015 at 20:43
barrym
Thanks mate, that is exactly what I was thinking.
I was pretty confidant of my diagnosis but it is always nice to have it backed up!
Will try the blue sensor when I get it and if that doesn't do it then I guess temp gauge is next in line for replacement.
Mine doesn't have a brown sensor, the fan switch is on the rad so completely different circuit and wiring which helped 'convince' me I could still drive the car, albeit bricking myself.
Might take you up on trying out the green one though, mine has started to not respond to throttle when you try to pull away, but only once when started first thing in the morning. Maybe temp related?
Hmm, I wonder if this is related to my blue plug problem? Maybe a fault in the loom as they are so close together.
BTW no still haven't seen you about either bud
Barry
Posted 1st Sep 2015 at 20:48
barrym
Thanks welshy!
So could a blue 2 pin sensor over read on the temp gauge but not illuminate the STOP light as I am experiencing?
Posted 1st Sep 2015 at 20:50
yep, certainly possible, if the fans are coming on and off as normal when the gauge is showing silly numbers then it certainly does seem like a faulty sender, OR wiring.
part throttle low speed hesitation could be map sensor or lambda.
Posted 1st Sep 2015 at 20:57
cully
also check the earths from the gearbox to the chassis and to the battery Wink
Posted 1st Sep 2015 at 20:59
6waysforward
Barry
Doh Sorry i forgot you have a rallye, not a gti.
Yeh what welshy said. Oh and yes i had pull away probs to which was a lamda. Might have a spare of of them you can try to. LOL
Posted 1st Sep 2015 at 21:03
barrym
Thanks for that, I am so glad it is possible!
It was the silly numbers that really seemed odd to me. if the car sat in the red it would have stayed where it was and got towed, but going way past just didn't add up.
Will keep fingers crossed and hope the new sensor cures it.
Had a new Bosch sensor last month and hesitation didn't happen before cambelt was replaced last week
Posted 1st Sep 2015 at 21:10
barrym
I will have a look at that too, thanks mate Thumbs up
Posted 1st Sep 2015 at 21:11
6waysforward
So you have a new bosch lamda sensor and it didnt hessitate. Now the cambelts been done, its hessitating Hmmm
Who did the cam belt?
Posted 1st Sep 2015 at 21:17
barrym
A local garage mate. I don't think its a big deal, it just coughs once when pulling away cold in the morning.
What are you thinking?
Posted 1st Sep 2015 at 21:20
6waysforward
Suppose it could be down to the coolant senor to. Well if it was hessitating alot then i would say it could be the timing but if it seems ok after the first cough then its probably not.
Posted 1st Sep 2015 at 21:32
barrym
It is literally one, not even cough,just doesn't pull for a second then all is fine.
I can totally live with it.
Will get my temp issues sorted as a priority (hopefully) and go from there.
Thanks for your help guys, will let you know how I get on. Or bend your ears for more advice.
Hopefully the former though
Cheers Barry Thumbs up
Posted 1st Sep 2015 at 21:38
barrym
Ok so new sender turned up today. Just fitted it and taken car for a test drive and......
problem solved!
Gauge works properly and temps are absolutely normal, no coolant lost over the last 2 days, or ever even.
Thanks for everyones help, very much appreciated.
Barry
Posted 3rd Sep 2015 at 18:23
MisterGTR
Good to hear Smile
Posted 4th Sep 2015 at 00:19
Craig g
Mine has the same symptoms.... Hasn't been used a lot and has had a lot of work on it, and on the run home from the garage temperature gauge went through the roof but the fans didn't kick in.
I have had problems with the matrix which I'm in the process of replacing but I did think I was into head gasket problems, water pumps etc... But I think I'll try changing the sensor first...
Craig
Posted 19th Sep 2015 at 18:39
mocinim
Craig
Are you getting your matrix from peugeot or do you know a cheaper model good quality
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 19th Sep 2015 at 20:10
Craig g
I got a replacement unit from Peugeot just to be on the safe side!
Posted 19th Sep 2015 at 20:15
