Author Subject: Brembo RS 310 Adapter
ash
Six Addict
To fit RenaultSport Brembo with 310mm rotor. One adapter no bell. Useless on it's own but if you have aspirations to use this adapter with a different size disc then this could be the starting point. As the calipers are radially mounted this adapter could be converted to run a 300mm disc by machining 5mm off the mounting surface; conversely a 2.5mm spacer wood convert it to run 315mm discs.
If you want another one it can be made as a one off for about £100 or as a pair to your spec for £150-200.
This one only with text mistake £40
Posted 22nd Aug 2015 at 23:38
ash
Six Addict
Sold
Posted 24th Aug 2015 at 22:26
ravemercer
Hi Ash would you be able to get brackets made up for your original rs310 kit as i've got refurbed rs brembos callipers needing adapters bells too ?
Cheers dave
Posted 30th Aug 2015 at 20:50
ash
Six Addict
Yes no problem I can get them made for you.
Posted 31st Aug 2015 at 21:43
But can we get brackets made to fit calipers under 15s for std wheels dude ?
Posted 31st Aug 2015 at 21:46
ash
Six Addict
I'm pretty sure that the RS calipers won't go under std 15" Cyclones as they were originally designed for 17" wheels. I can get some made to fit whatever disc you want to try - 295mm?
Posted 31st Aug 2015 at 21:54
That might fit under the speedlines on the 205 ? Not cyclones bud ?
Posted 31st Aug 2015 at 22:14
ash
Six Addict
Yeah might do.
Posted 31st Aug 2015 at 23:56
the bulk of the caliper is the main issue, they will go under a 15" wheel at 310mm, but they have to be a motorsport type wheel with big clearance, and a small spacer if theyre not wide.
rally design's 285mm wilwood kit goes under a 205 wheel with a 5 mm spacer,
Posted 1st Sep 2015 at 05:56
ravemercer
I've tried getting the 310mm Rs Brembos under 15" PR2's and they wouldn't fit. The brake pipe fittings and pipe were the issue iirc hitting the angled piece of the inside of the rim by the spokes even with 25mm spacers and -10mm offset rotor they wouldn't work. It would take something like a 40mm spacer and I'm still not sure it would go at 310mm.
Posted 1st Sep 2015 at 17:59
they go under 6" wide MO's with just a 10mm spacer.
Posted 1st Sep 2015 at 19:30
Just. With a bit of weight loss.
Posted 1st Sep 2015 at 20:05
Well here's my 2pence worth ....Not what your looking for ..Ashs 330s go under 16s with no spacers at all .!!!Whistle
No chance going under 15s though LOL
Posted 1st Sep 2015 at 21:36
ash
Six Addict
Cheers guys.
Someone asked how much for an RS310 kit? As a one-off will be £350 or £300 per kit if I get 5 made but I'd need 5 definites and would need to be anodised the same colour, I suggest black.
Posted 2nd Sep 2015 at 10:38
