Author Subject: Magnex system
Thomsongti6
Looking for info as I got my hands on a "magnex" centre section in very good condition for much cheapness, it looks a hell of a lot bigger than the sportex one I have now (just a cheapy until I got the magnex), also doesn't have the flanges either end its just straight, so I'm guessing I need a magnex rear silencer and decat as it won't fit the system I've got just now. I emailed magnex and they don't make the systems for the 306 anymore, so I have been looking for just the decat and rear silencer and no where sells them and I'm not paying £400+ from spoox for what I have minus the back box, I would be happy if I could just find a back box I could get a decat made to fit just nicely
Posted 28th May 2015 at 20:10
6waysforward
A magnex uses the sleeve type connection as you have already found out where as a sportex used the factory spec flange fittings.
Keep an eye on here, 306oc and ebay as lots of people sell magnex back boxes, used of course. There was one on ebay recently but I think it sold.
You do not need a de cat. The cat has a tube that the magnex centre section slides onto, you just put a exhaust clamp on it.
Posted 28th May 2015 at 21:08
Thomsongti6
Perfect cheers buddy appreciate it
Posted 28th May 2015 at 23:07
RetroPug
Nothing to stop you picking up the rear silencer of your choice and having the joint cut off and a sleeved-type joint welded on.
Posted 30th May 2015 at 08:43
I bought a second hand Magnex 2.5 & had all the sleeving cut off & two bolt flanges welded on by Infinity exhausts in Bristol as sleeving was blowing a little in places & they fitted flange gaskets same as these below.... Now100% nothing Thumbs up
Posted 30th May 2015 at 19:54
RetroPug
Mongoose systems bolt together like that as well, no leaks and easy to fit.
Posted 30th May 2015 at 19:19
