Author Subject: idle issues
stuartdowers
Picked up my 3rd gti 6 at the weekend, 200 miles home and was almost fine. Except the rev counter had a mind of its own, just sits at 6000rpm, then when driving comes off the clock! any ideas?
Problem no 2. Went out to it Sunday morning stated the car and idle was all over the place. Even once warm it was still doing the same. Same again this morning.
although the 2 problems were at different times i'm wondering if they could be linked, wondering if it could be throttle position sensor or idle control valve??
stu
Posted 27th Apr 2015 at 08:28
mocinim
Just brought a rallye with the same issue although not quite so high with the revs replaced the icv mag marelli item (dont go cheap its not worth it )problem almost solved got to a point where it would not tick over at all or just revved at 3 K REVS quick clean of the map sensor and all is now smooth
am expecting to need a mew lambda also as its is a bit fuel ritch at the exhaust
it will most likely be one of these three
try carparts for less for icv saved £40 marelli type can be foun on the fleabay
O and reset ecu after if you can get faults cleared properly e.g by plugging it in is the best way
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 27th Apr 2015 at 15:21
stuartdowers
well just went out and had a play, blocked the ICV with my finger, cut straight out, done this twice, problem has 99% gone, so assume ICV is sticking, just ordered one so fingers crossed
stu
Posted 27th Apr 2015 at 15:52
mocinim
Sounds like icv i cleaned mine thoroughly and it held on for two or so weeks it then died ! new one 😆 sorted
Dont forget to clean inside and beware the screws they supply they may not fit properly and can chew up your thread
Posted 27th Apr 2015 at 17:28
stuartdowers
drove home from work and idle is still not quite right, but a lot better so waiting for the new ICV, the rev counter seems to work one min, then the next its at 10,000
stu
Posted 28th Apr 2015 at 08:02
mocinim
If its red lining randomly dont use it till its fixed dont risk the engine how old are the belts etc etc still sounds like icv
Posted 28th Apr 2015 at 09:04
stuartdowers
no its not actually reving that high, it idles from roughly 1000rpm to 2500rpm, but the rev counter seems to think idle is at 6000rpm, and as soon as I move it goes to 10000rpm
stu
Posted 28th Apr 2015 at 09:16
mocinim
What phase and year is it
Posted 28th Apr 2015 at 20:38
mocinim
http://www.306gti6.com/forum/showthread.php?id=65659
Old thread has some similar issues maybe worth a look
Posted 28th Apr 2015 at 20:48
stuartdowers
its a phase 2 I believe 1998
stu
Posted 29th Apr 2015 at 09:50
6waysforward
Yup that's ph2.
Leave the icv in soak over night, normally helps.
Or get a new one.
Posted 29th Apr 2015 at 20:36
mocinim
Did it sort !!!
Posted 5th May 2015 at 09:02
