One in each front corner either sideways tyre to tyre or long ways facing windscreen ?
Any feelings on way better / right or wrong or even looks better a particular way ?
displaying posts 1 to 25 of 45
| Author | Subject: Which Direction Aero catches best on 6 bonnet |
Seems people are putting the surface catches different ways ?One in each front corner either sideways tyre to tyre or long ways facing windscreen ? Any feelings on way better / right or wrong or even looks better a particular way ? |
allanallen
Seasoned Pro Location: Buxton Registered: 01 May 2007 Posts: 1,399 Status: Offline |
It says in the instructions that you fit them north/south, smallest end forward.________________________________________ www.bridgecraftmotorsport.co.uk |
allanallen wrote: It says in the instructions that you fit them north/south, smallest end forward. I should of read them then .!!! Thanks Allan |
allanallen
People fit them all over the shop, I don't think it's frowned upon ________________________________________ www.bridgecraftmotorsport.co.uk |
yes it is ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
welshpug! wrote: yes it is ![]() So as per instructions that I didn't read ? Or Mei going to give me grief when he drives my car ? |
Cjwatson27
I'm glad you asked this question has I can't figure out why my catch keeps sticking so thinking of fitting them too________________________________________ Old pugs don't die they just get faster |
Cjwatson27 wrote: I'm glad you asked this question has I can't figure out why my catch keeps sticking so thinking of fitting them too Chris I wasent going to .. .....but thanks to Allan and Him being so helpful |
Another job done Day666 has attached the following image: |
mik
Seasoned Pro Location: Kent Registered: 17 Feb 2011 Posts: 2,100 Status: Offline |
Why do people fit aero catches? Serious question - I've never felt the need. Are they more secure than std?________________________________________ Cherry Rallye SOLD |
rallyeash
Well I don't have a slam panel! ________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
Cjwatson27
My internal realise catch has broken twice I've replaced the cable and the catch seized so I'm thinking of fitting them ________________________________________ Old pugs don't die they just get faster |
I fitted aero catches to my boot because I got rid of central locking so had no way to secure the boot. I fitted mine to the bonnet because I wanted to get rid of the std pull mechanism as the cage sits where the lever would have gone, and soon I'll have a composite bonnet which won't utilise the hinges so I'll be needing some more to secure that. Mine is a track car though so will never be entered into any show and shine type things ![]() ________________________________________ Goldie the track car. |
mik wrote: Why do people fit aero catches? Serious question - I've never felt the need. Are they more secure than std? To be truthful I'm removing my middle catch because I have keyless entry & when my battery goes flat it's a sod to open the car ....plus last Combe track day I forgot to to push my internal catch back fully as the cables stiff & the bonnet opened to the first safety latch ...scary I think others with fibreglass / carbon bonnets do it because of flapping when track day ? You can see my two solar panels charging the battery ...the car doesn't get used much and when it goes flat it's a nightmare with no door locks anywhere on the car |
with the composite panels most don't have the facility to use the standard catch.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
allanallen
mik wrote: Why do people fit aero catches? Serious question - I've never felt the need. Are they more secure than std? What's happened to this forum?! Someone should have popped up by now saying 'cos motorsport FTMFW!' or similar..... ![]() ________________________________________ www.bridgecraftmotorsport.co.uk |
Just one rubber Mallet tap for minor adjustment & SNAP Day666 has attached the following image: |
I think i saw that you can get steel versions which will be stronger. ________________________________________ Goldie the track car. |
prism7guy wrote: I think i saw that you can get steel versions which will be stronger. Yes Steve these are poor quality ...I tapped it so soft needed 2mm to the right for 100% & the Alloy just cracked then fell off ... Defo Some sort of steel ones needed |
eddy_gti6
I had a couple of them if you want one sent out mate?________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
pugheaven
Seasoned Pro Location: Fareham Registered: 17 Dec 2006 Posts: 4,602 Status: Offline |
Did you buy genuine ones or eBay ones, iv bent mine a fair bit and they haven't snapped yet lol |
eddy_gti6 wrote: I had a couple of them if you want one sent out mate? Thanks Chris Ollie I bought them off Merlin at Combe ....never buy anything off Fleabay |
eddy_gti6
Were they genuine aerocatch ones? The ones i have had twist and bend and never snapped________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
I bought mine from Rallydesign from memory, so should be genuine. They feel too light to be strong though ![]() ________________________________________ Goldie the track car. |
demondriverdan
Has anyone got photos of how they have attached them for the boot?________________________________________ Rallye Race Car |
