displaying posts 176 to 200 of 381
Pages (16): first .. 7 [8] 9 .. last
Author Subject: Satchshift brief fitting guide
Chr1sch
Post #176
still waiting...
Posted 17th Jun 2015 at 15:00
Post #177
I didn't think the new super boot was finished yet ????
I know they wanted it 110% right before making & releasing anymore ???
It's worth the wait Guys Thumbs up
Posted 17th Jun 2015 at 15:08
pugheaven
Post #178
Iv got the new boot but haven't got round to fitting it yet
Posted 17th Jun 2015 at 16:15
Post #179
So you don't 100% know if it works yet ????
I've still got a nice clean hole that's keeping my toes warm with NO issues !!!!
Posted 17th Jun 2015 at 16:33
Chr1sch
Post #180
Has anyone got theirs yet?
Posted 18th Jun 2015 at 16:32
Post #181
Tony said its on the way Smile
Posted 18th Jun 2015 at 16:40
Chr1sch
Post #182
It's arrived!! :-)
Posted 18th Jun 2015 at 19:49
Post #183
my new boot has arrived too Smile
will get round to fitting it soon!
Posted 19th Jun 2015 at 13:03
Post #184
Me too
Looks great
Thanks Dave Thumbs up
Posted 19th Jun 2015 at 15:10
Chr1sch
Post #185
i'm assuming most of the boot will be inside the car?
I must say the kit is beautifully made, just quite intimidating with no instructions or template etc :S
Posted 29th Jun 2015 at 15:55
Chr1sch
Post #186
Day666 wrote:
Mei 220mm from top of Subframe to the middle of the hole paper template
So as I dont have a template, can i check, that is a measurement straight up from the top of the subframe to where it hits the bulkhead - where it hits is the centre of the hole?
Posted 29th Jun 2015 at 15:59
Post #187
Yeah i think that's where i positioned the centre of my hole. I think i did a 32mm hole but i've had to enlarge it a bit downwards.
For some reason i can't select 5th or 6th on my box, nothing to do with the satchshift kit as even with it disconnected i can't pull one of the selector arms out which i believe it needs to do to get 5th and 6th.
Could it be from lifting one of the selector shafts up a bit in order to drive the roll pin in? I'm pretty sure i kept the spring thing in place under the new selector arm. I should add that the 'box is dry of any oil and no driveshafts are in, so maybe i just need to put the shafts in with some oil and rotate it a bit to maybe help line things up? Dunno
Posted 29th Jun 2015 at 21:37
Post #188
Yes Thumbs up
Contact TIGgerDave on this post & he will send you one out Thumbs up
You can fit it without but I wouldn't want to try it unless you have already fitted one !!!!
Posted 29th Jun 2015 at 21:47
Cjwatson27
Post #189
Is it wrong this is one of the main reason that's got me thinking about buying another 6
Posted 29th Jun 2015 at 22:03
pugheaven
Post #190
Stephen, the same happened with my 5th and 6th, when swapping the selector arm over on the box the shaft dropped down and rotated, you need to take the arm back off push the shaft down and turn it clockwise as your looking into the engine bay, pull the shaft back up and fit the arm and check it turns equal distance left and right
Posted 29th Jun 2015 at 22:24
Post #191
Ahh, thanks Ollie, i'll try that tomorrow evening. Have you got any tips for getting the roll pin in and out? I found it a pain in the arse when i did it last time, im pretty sure there was one roll pin inside another, unsure whether it was meant to be the case or not though.
Posted 29th Jun 2015 at 22:32
Chr1sch
Post #192
I have to say it's some sexy kit, the finish is epic!
Posted 29th Jun 2015 at 23:17
pugheaven
Post #193
Those roll pins are a pain in the arse, yup meant to be one in side another and are NLA from Peugeot! I had to use a rivet gun to remove mine, I replaced mine with an m5 bolt Thumbs up
Posted 30th Jun 2015 at 00:16
Post #194
For me ....the roll pin was the most difficult thing to do !
Getting out we made a 4foot 10mm hollow tube bar with a punch pushed into the end with a bolt stopping it getting pushed into the tube.... we could then tap with a small hammer from a distance & see what we were doing also with a light at the same time ....you can't get into that area that easy it still took 30 mins though Thumbs down .....then with the bar on a angle underneath the car to passenger side over the top of the subframe and into the front L/H wheel area you have room to tap out ...PS the roll pin looks like two ...but is one ....have the correct size Punch or it damages the pin & it jams ...just a little smaller than the out side of the pin ...
Getting it in is no problem just file the end your tapping back in a little & I used WD40
Posted 30th Jun 2015 at 08:02
pugheaven
Post #195
The roll pin is 100% 2 items I thinner diameter in the middle which you should get out first then the larger one, both mine and Ross's had two and miles informed me that there where two
Posted 30th Jun 2015 at 10:34
Post #196
got a pic of which bit you mean to be the "top of the subframe" ? as its
not a very flat thing, whereas the bottom is :p
changing my flywheel soon hopefully, so I'll do it and get the engine out as there's no chance of getting a drill in there otherwise.
using a bolt for the selector arm isn't wise as it needs to be a tight fit.
Posted 30th Jun 2015 at 11:41
Post #197
Mine came out as One ...I didn't look closely I must admit .....but I can remember it looked solid & had a very small hole !!!
Posted 30th Jun 2015 at 11:45
pugheaven
Post #198
The bolt is a tight fit, it's a bolt not a screw so has a long shank which is the same diameter as the hole (slight interference fit)
Posted 30th Jun 2015 at 12:09
Chr1sch
Post #199
As daft as this may sound, how the heck are we meant to know what goes where? I don't have any instructions etc? Obv I will follow the instructions etc in this thread as best I can but even they jump about a bit - does anyone have a clear step by step?
Posted 1st Jul 2015 at 08:12
Chr1sch
Post #200
Day666 wrote:
Picture below .....once heater lower 50mm base is removed on post before this one & angle bracket below leaving threaded bolt in middle of bottom of the picture below & cut back really carefully as it you have rain sensor w/s a loom is below Foam & you can't see it ....be warned going extra carfull you can't see it under the foam & it's 8 wires & I cut 5 of them by going careful !!!!
When you start to fit it & take apart you will see what goes where easily Thumbs up
On this pic, just approx where is the hole?
I've now removed carpets etc etc and I can see with the dash in its going to be very entertaining...did you drill your hole from inside,
Thanks for this guys, I've got a mechanic mate who will ultimately for it but he doesn't know half of what I do from here so trying to compile some sort of guide for him...
Posted 1st Jul 2015 at 08:16
