displaying posts 376 to 381 of 381
Pages (16): first .. 14 15 [16]
Author Subject: Satchshift brief fitting guide
blandy
Post #376
yes i run a similar manifold and ended up with issues as the rod hit the manifold but was incredibly close so 10mm more would of cleared it- the upper rod is what caused the issue. I spent alot of time trying to adapt the rod in order to avoid the manifold - which worked but ultimately just made it less precise to change so kinda defeated the object of the satchshift... 100% worth it if it fits as intended though
Posted 5th Oct 2020 at 10:32
Post #377
make the exhayst oval..
Posted 5th Oct 2020 at 17:54
ew10lior
Post #378
Hello everyone,
This is my first post here, Roll eyes
I'm just bought this kit for Citroen XSARA...
I'm looking for some tip's for install it,
My Engine is the EW10, With C4 VTS manifold, should be problem to to fit?
And about the Hole that need to be drill, if i take the Gearbox off (I replace it any way) it will be easier to drill or take off the dash is the only way?
Thanks for any advise,
lior dinar
Posted 27th Dec 2021 at 09:16
Post #379
ew10lior wrote:
Hello everyone,
Sadly i dont think many can give must help ?
Nearly all run gti6 engines / some with 4/2/1 manifolds that have stopped fitment …
Good luck m8
Regards
Damien
Posted 30th Dec 2021 at 16:46
Post #380
the ew10 in a xsara sits further forward rotated about the crankshaft axis I believe, the gearbox itself is in the same place.
you mqy have more space as the ew10 4 branch used a clamp joint rather than cone and flange, its shape is otherise very similar to the gri6 I believe,
many seem to have done the installation without removing anything, however I would personally just remove the whole engine and box if I had more time, easier than taking the box off the engine really
Posted 31st Dec 2021 at 11:50
marksorrento205
Post #381
I’m with WP on this one.
Having fitted them to 306’s and 205’s both with and without the engines being fitted, you will achieve a better job with the engine and box removed. Removing the gearbox alone will give you slightly better visibility, but either go for the lot or don’t bother Thumbs up
Posted 1st Jan 2022 at 19:10
