Author Subject: 306 XSI front brake calipers
jord294
as title, please gents
266mm version brake calipers wanted in good useable condition.
good discs and pads would be a bonus
thanks
Posted 5th Mar 2015 at 08:08
Are they the same as HDi items?
  • Posted 5th Mar 2015 at 09:39
    jord294
    all i want is calipers to use the 266mm discs
    according to servicebox there are various models that use the discs, but differnt part numbers for calipers
    i need bot on discs and calipers for a 205 gti
    cheers
    Posted 5th Mar 2015 at 13:14
    aaron6
    Yes. The hdi are 266mm ones.
    Posted 5th Mar 2015 at 13:22
    I shall check them over Thumbs up
  • Posted 5th Mar 2015 at 13:26
    eddy_gti6
    Gti6 brakes bolt straight onto the 205
    Posted 5th Mar 2015 at 14:54
    the p1 xsi ones have like a bit at the bottom of the caliper mounting carrier. i don't recall my 306 hdi ones having it, yet they use the same disc
    Posted 5th Mar 2015 at 14:58
    jord294
    I know that mate, but don't like how gti6 brakes feel on 205.
    I had a 2000 306 xsi years ago and thought thd brakes were a lot better
    I can't really fault o/e 205 gti brakes. Just want to try xsi
    306 xsi caliper style, certainly from the p1:
    http://i140.photobucket.com/albums/r36/keith106/Project%20xsi/a13.jpg
    306 hdi caliper:
    http://i1047.photobucket.com/albums/b471/GKZ_206/022-4.jpg
    Posted 5th Mar 2015 at 15:00
    scotzman
    406 non abs master cylinder on mine and pedal feel is spot on.Thumbs up
    Posted 5th Mar 2015 at 16:56
    martinh
    Have you got a part number for the master cylinder mate?
    Posted 5th Mar 2015 at 18:37
