Author Subject: Gti xsi radiator differences
6waysforward
Just having a look at the differences between the 2 rads and the only difference I see is the take off hose on the header tank for the heat exchanger, is this correct?
Been thinking of binning the heat exchanger for a while. Been told you can just take it off and put the oil filter back on? Is that correct? Or get a Mocal oil cooler with thermostatic plate. And obviously changing the top rad pipe.
Can't seem to find any new nissens rads, only xsi ones. The heat exchanger take off hose is in the way of boost pipes anyways so would be nice to ditch it if poss.
Any help is greatly appreciated.
Posted 22nd Feb 2015 at 18:59
Yeah you can do away with the heat exchanger and fit an oil filter with a 205 threaded insert.
I've a used Nissens rad in '6 fitment surplus here.
  • Posted 22nd Feb 2015 at 19:20
    sergioiacobucci
    Just looking up info on this. To clarify if i am getting rid of the heat exchanger an xsi rad will fit? Exactly the same apart from this?
    Phase 1 silver track car
    335i daily
    Posted 5th Jan 2017 at 08:43
    sergioiacobucci
    Anyone?
    335i daily
    Posted 7th Jan 2017 at 17:37
    Cjwatson27
    I am trying to think what I changed when I upgraded my xsi to a gti6
    Posted 7th Jan 2017 at 17:41
    sergioiacobucci
    Let me know if it springs to mind!
    335i daily
    Posted 7th Jan 2017 at 18:14
