| Author | Subject: Rear brake pipes |
Sonnyp
Regular Location: Canvey island Registered: 16 Apr 2014 Posts: 126 Status: Offline |
Can you do away with the copper rear brake lines that go to the calliper with some custom braided ones? I've got braided rear lines to replace the flexie ones with the spring around it. |
Twangy
Senior User Location: heswall Registered: 27 Jun 2014 Posts: 623 Status: Offline |
you can do the whole car with braided ones if you like________________________________________ wayne mcardle |
Rich E
Yeah you could, but I don't see why you'd need / want to...________________________________________ Rich |
Sonnyp
Only asking as my rear lines are a bit tatty and I'm changing my beam over soon to a new one. Rather not have to make some new metal ones up |
Braided lines made up for the section you want won't be cheap. Some motorfactors will make you a copper line up with the appropriate ends for little money. You may or may not realise you can buy the steel lines in sections from Peugeot. I'm unsure on pricing but Servicebox will tell you or a phonecall to your dealer even. I'd recommend finding someone with a flaring tool and buying a roll of copper pipe for a tenner with some fittings. You'd be surprised how easy it can be to get a decent flare WITH A DECENT TOOL. ________________________________________ ![]() |
Sonnyp
Got the tools and pipe at the workshop that I mess about with the car in, just wondered if people had used braided lines before for that section, just being lazy after the effort of redoing a beam ha.On another note I have a mechanical brake compensator on the rear it's gonna be lowered say 30- 40mm, on another thread they said to adjust it by 10mm, but is it as easy as just shortening the spring or do they mean the whole thing ie. the metal rod holding it in place? |
burnout21
Regular Location: Edge of the Pass Registered: 23 Apr 2008 Posts: 248 Status: Offline |
My lines are knackered on the joins that connect to the beam. Rather than replacing the whole lines, how easy would it be to just replace the lines after the fuel tank? Not got the tools required. |
easy enough, depends which line you mean, from front to load compensator, or compensator to flexi brackets?youll need some tools regardless, or pay someone. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
burnout21
Its the joint that goes through the beam brackets (that the beam mounts to chassis) top part of Flex pipe. (If that makes sense) Both sides. Don't mind paying someone, as not got time to do all piping myself. Problem is car is not moveable. Pipes are leaking as the nuts have corroded that bad. |
gnrlee
Forum AdminLocation: Leeds Registered: 20 Aug 2005 Posts: 8,891 Status: Offline |
a genuine pipe from pug is silly money for what it is!I just bought a tool and did my own but if this is the route you go down make sure you get a tool that will flair a steel line! ________________________________________ Proud Member of the ASTOR Owners Club |
gnrlee wrote: a genuine pipe from pug is silly money for what it is! I just bought a tool and did my own but if this is the route you go down make sure you get a tool that will flair a steel line! reeeallllyyyy? did you check? 4803E7 BRAKE HOSE 12.68 GBP 4803G3 BRAKE HOSE 1.73 GBP ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
gnrlee
£1.73 for a hose,... from peugeot??? Cheeky sod said i had to buy pretty much the whole rear of the car! ![]() Well it's done now! ok for your next trick,... is to be able to unscrew the break line nut without destroying it because their made of Cheese! ________________________________________ Proud Member of the ASTOR Owners Club |
brake, not break ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
gnrlee wrote: ok for your next trick,... is to be able to unscrew the break line nut without destroying it because their made of Cheese! Don't use a spanner - use the proper tool. Or just snip the line you are replacing and get a 6 sided socket on it ________________________________________ ![]() |
rikky
proper brake pipe spanners are a must with pretty much anything________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
burnout21
Nope, the but is Fubard, rounded off like a blob of Lard. Annoying, why I need to sort it. |
mocinim
Seasoned Pro Location: The Darkside of bedford :) Registered: 09 Jan 2015 Posts: 2,307 Status: Offline |
Hi guysIs Copper Nickel, Kunifer Brake Pipe better than standard pipe need to replace mine just ripped of my nipple ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
MisterGTR
Senior User Location: Glasgow Registered: 05 Aug 2014 Posts: 675 Status: Offline |
rikky wrote: proper brake pipe spanners are a must with pretty much anything Can you link to what you mean. flared spanners? ________________________________________ Turned 40 and in true cliched fashion buying one of the cars of my teenage dreams! |
RetroPug
mocinim wrote: Hi guys Is Copper Nickel, Kunifer Brake Pipe better than standard pipe need to replace mine just ripped of my nipple Kunifer is supposed to be a bit better but copper is absolutely fine and easy to work with. I'd never flared in my life, watch a quick youtube video on it and I did all the lines to rear calipers plus repaired some sections of front with a cheap tool. I did borrow a decent one for the steel lines though. ________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
