Author Subject: rear damper question
cornish_pug
I've started a few threads about rear suspension because I still can't pin point what is up with mine.
It's a knock over rough ground under braking. I've been told to check calipers for loose bolts but they're fine. Also I was told to check the beam mounts but they were new 3 years ago.
FYI i did a full beam rebuild 3 years ago.
If it helps, the knock sounds like two pices of steel tapping against each other.
Team Diesel
Posted 1st Jan 2015 at 16:21
cully
loose heatsheild/spare wheel cradle ?
Posted 1st Jan 2015 at 16:24
cornish_pug
When the boot has a dead weight in it the knock virtually disappears altogether
Team Diesel
Posted 1st Jan 2015 at 16:29
Anti rattle springs correctly fitted to rear pads ?
Posted 1st Jan 2015 at 17:02
Brake compensator
Posted 1st Jan 2015 at 17:16
jord294
Bolts tight that hold arb levers??
Posted 1st Jan 2015 at 18:09
Knock over bumps particularly when cornering or braking or both is knackered beam mounts usually. Were they genuine pug ones or cheap ones? I've had cheap ones last 6 months before..... Genuine ones last years.
However it's more Of a loud thudding from the back over bumps than a metali noise though.
I've had a very similar noise on a beam when the Rubber ARB seals were completely fooked so the ARB jumps about and clangs against the beam tube.
Posted 1st Jan 2015 at 19:10
allanallen
As above, arb end plate rubbers Wink
Facebook
Posted 1st Jan 2015 at 19:42
cornish_pug
That's what it sounds like
Team Diesel
Posted 2nd Jan 2015 at 00:20
still need to check stuff even if you have replaced it not unknown for non o.e mounts to fail quickly.
Posted 2nd Jan 2015 at 10:05
rallyeash
Mounts. My brothers Rallye used to knock bad under serious braking.
309 3dr K20 Type R
Posted 2nd Jan 2015 at 11:41
Would a mount thud not be more of a knock opposed to metal clanging together like the OP suggests?
I had a metallic clanging and it was the bolt holding the ARB end flag on coming loose.
  • Posted 2nd Jan 2015 at 12:25
    I had this in my old beam,
    Never caused an issue but it was ANNOYING AS HELL.
    I always assumed it was the rubbers
    Posted 2nd Jan 2015 at 16:52
