Also who makes these and i have seen some have a small bush in them?
Marty
206 Rallycross GTI6 SC SHB 425 BHP clutch eater !!!
| Author | Subject: solid bottom engine mounts |
Hawkesfire
Regular Location: Stockton on tees Registered: 26 Mar 2013 Posts: 180 Status: Offline |
Hi i have seen these before but can not find anything on the search engine here so looking to get one for the rallycross car but are they Ok or do they cause problems or snapping things?Also who makes these and i have seen some have a small bush in them? Marty ________________________________________ 206 Rallycross GTI6 SC SHB 425 BHP clutch eater !!! |
rikky
completely solid or harder 'uprated' ones?colin satchell made my completely solid one from turned ally. combined with the other solid mounts it made for serious vibration but did the job perfectly ________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
Constella make them I belive? |
jamiek_uk2000
Phillipm used to do them, but I don't think that he is on here any more. Not sure if anyone has a contact for him________________________________________ 205 GTi Red - G939 RTU - Died!306 GTi 6 Diablo - Being resurrected! Project Thread Looking for: VTS P1 Rack PR1.2 16" |
http://306oc.co.uk/forum/user-152.html HTH ________________________________________ ![]() |
Cjwatson27
You after a solid aluminum one for the bottom mount ? ________________________________________ Old pugs don't die they just get faster |
Hawkesfire
Yes please you got one if so how much ??Marty ________________________________________ 206 Rallycross GTI6 SC SHB 425 BHP clutch eater !!! |
Cjwatson27
I'll have a look see what i paid, can you collect ? ________________________________________ Old pugs don't die they just get faster |
fatlapit
any turning firm can make them________________________________________ |
fatlapit
271654960529ebay ________________________________________ |
fatlapit
http://constella.co.uk/home/index.php/component/virtuemart/conversion-parts/group-a-solid-lower-engine-mount-detail?Itemid=0 ________________________________________ |
Cjwatson27
Got one here already fitted in a housing ________________________________________ Old pugs don't die they just get faster |
allanallen
Seasoned Pro Location: Buxton Registered: 01 May 2007 Posts: 1,399 Status: Offline |
I used a solid nylon bush in my 205 rally car, teamed with the harshness of the paddle clutch it eventually snapped the lower engine mount fork, seriously ruined my rally ![]() If you're going to fit one I suggest you leave the little rubber bush in the lower fork. I'd personally go with a baker bottom mount and nylon fork bush though. ________________________________________ www.bridgecraftmotorsport.co.uk |
rallyeash
I had a solid engine mount and the housing snapped after. While. Changed the mount/housing with a hardened rubber one. Much nicer drive________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
aaron6
I'm with allanallan. Stilly had very solid engine mounts and the stress was transferred straight to the chassis nearest the mounts and put some substantial cracks in. I had to weld large plates on to stop it happening again. ________________________________________ See the sheer power and might of the lesser known burrowing owl. |
superchargedblack1997gti6
Phillip m built some custom mounts classified as semi solid, I have used this and a constella solid item I'd typically say for you're car hawkesfire I'd go fully solid? If you're after a Phillip m semi solid give me a pm.Thanks ________________________________________ Super high boost Completed, destroyer of gearboxes and 160mph club |
BigTallPaul
Junior User Location: Leicester Registered: 02 Jun 2013 Posts: 90 Status: Offline |
Group A Baker BM here -----> http://www.bakerbm.com/306.php?data=engfbusha306 for just £17 ! Good Luck Marty. |
BigTallPaul wrote: Group A Baker BM here -----> http://www.bakerbm.com/306.php?data=engfbusha306 for just £17 ! Good Luck Marty. thats just the fork bush not the large one. if you want solid you need to do all three, otherwise any flex will be transmitted into the shell violently through the solid one. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Hawkesfire
Thanks gents i have got a solid unit now will try next year as currently space framing front end to get some castor on the car and then we start to remove whole rear floor section from the cage back over.We will also be looking to drop the engine height as well to get the COG as low as possible ....... Lots of work !!!!! ________________________________________ 206 Rallycross GTI6 SC SHB 425 BHP clutch eater !!! |
