Author Subject: Head Gasket Tightening
Eddleston
Ok, I've done
35nm
Then went round on
70nm
Now, for 160degrees do I just need a f**k-off extention bar?
Seemed pretty tight at 70...
Sorry to keep asking but I'm learning and don't like doing the same job twice.
Posted 25th Oct 2014 at 17:49
fatlapit
u got an angle guage??
Posted 25th Oct 2014 at 18:05
fatlapit
tbh id just 180 it
Niall
Yeah you need a angle gauge. Got one over here if you want to come and borrow it.
I angled mine and had to use a 2ft breaker bar to do so. My first one i did i was worried i would snap the bas**rd but they won't! Just make sure you get the washers in there as well and makes life a tiny bit easier if you put a bit of grease on the washer.
Posted 25th Oct 2014 at 18:07
Eddleston
That's on hold till tomorrow then lol
Posted 25th Oct 2014 at 18:26
cully
print one off from google Wink
Posted 25th Oct 2014 at 19:46
Eddleston
Well it turns out its actually really difficult to turn the bar at all when you've put your back out. Doh.
Is it supposed to be unbelievable f**king tight even from the first few degrees?
Posted 26th Oct 2014 at 14:32
barrym
I wouldn't have thought so. 70Nm is not a lot of torque.
Are you using new head bolts?
Black Rallye occassional toy
Posted 26th Oct 2014 at 15:45
Niall
That. Chances are if you are using the old bolts, they are at or past their maximum stretch tolerance. NEED a good set of bolts!
Posted 26th Oct 2014 at 16:22
Eddleston
Yep, got new bolts in
Posted 27th Oct 2014 at 00:53
demondriverdan
When I did my HG I could only get about 90 degrees with a breaker bar before it wouldn't move any more. That was using new bolts.
Rallye Race Car
Posted 27th Oct 2014 at 08:58
itll be gojng again soon then :p
Posted 27th Oct 2014 at 09:31
demondriverdan
I've got no idea how you're supposed to make it tighter. I was using a 1.3m breaker and couldn't get it to move any further!
Rallye Race Car
Posted 27th Oct 2014 at 10:00
sure you did 70 Nm and not 70 Lbft?
even I can manage the 160 degrees, and I'm a skinny bas**rd Razz
iirc the 8v goes to 300!
Posted 27th Oct 2014 at 10:57
jeffers Forum Admin
Did you put some oil on the back of the bolt heads? Something not right there if you can't tighten them, I did mine on an engine stand which is a dam sight harder than with the engine in the car....
Team Running Engine again!
Team Negative Camber!
Posted 27th Oct 2014 at 11:03
demondriverdan
Tbh I can't remember, it was a few months ago. Engine seems ok at the moment so I'll run it until I replace it or it dies!
Rallye Race Car
Posted 27th Oct 2014 at 11:42
daver6
I had no issues with tightening, but didn't realise until after that I should have had washers on. The bolts I removed didn't and the new bolts I bought didn't either
Wishbone Polybushes available
Posted 27th Oct 2014 at 13:07
rallyeash
If you don't have the spacer under the one nearest the master cylinder you'll bang a hole in the back of the block!
309 3dr K20 Type R
Posted 27th Oct 2014 at 13:20
not on an iron block LOL:
Posted 27th Oct 2014 at 13:45
probably still in the head, hopefully....
Posted 27th Oct 2014 at 13:46
Eddleston
I counted all the washers and they're all present and correct.
I'll take all the bolts out and try again then... When my back fixes itself.
Posted 27th Oct 2014 at 15:22
Eddleston
Posted 27th Oct 2014 at 15:24
barrym
Is it possible to hydraulic lock the bolts on these?
Posted 27th Oct 2014 at 17:47
quire probably, they're blind holes unlike the alloy block
Posted 27th Oct 2014 at 20:56
pete_rallye
Definitely possible, I know someone who ripped the threads out by hydraulic locking it. He'd got oil in the bolt hole...
Lap of the 'ring
Posted 27th Oct 2014 at 21:05
