displaying posts 1 to 25 of 46
Author Subject: Hi-Spec billet 300's - which discs?!
Chr1sch
Hi guys
I'm new here but have bought a gti6 withy the above brakes
Frankly they're crap, I mean really poor - currently have yellow stuff pads and grooved discs. (The latter look pretty knackered)
Can anyone tell me what discs I should use? Prev owner said he thought they were c4/307gt discs but wasn't 100%?
Also, if these brakes have been fitted does that deactivate the abs?!
Chr1sch has attached the following image:
Posted 3rd Aug 2014 at 23:53
Pads will be the prob
I'd get new discs and pads
Posted 4th Aug 2014 at 00:01
calibra306
I got ds2500 pads with my 330 hi-spec setup
V6 Power!
Faster I can go the better!
Posted 4th Aug 2014 at 00:47
Chr1sch
Ok great thanks, can anyone confirm what discs I should get?!
Posted 4th Aug 2014 at 05:56
only you, or the original purchaser can tell us that. wheel off and measure the diameter and height.
Posted 4th Aug 2014 at 11:09
Chr1sch
Cool no worries thanks
Posted 4th Aug 2014 at 12:02
Chr1sch
Hi gents, just measured the brakes, can i check what you mean by height?
As far as i can tell they are 305mm and 25mm thick (diameter is awkward as the centre nut protrudes but im pretty sure thats accurate)
Does that ring true with any common disc sizes people use?
Posted 5th Aug 2014 at 12:18
jamiek_uk2000
307 maybe. They are 302mm but not sure on thickness
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 5th Aug 2014 at 12:23
jamiek_uk2000
What's the overall height on the disc?
Check out brake parts. Co. UK.
Damn autocorrect
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 5th Aug 2014 at 12:27
Chr1sch
so assuming my understanding is correct and the height is the distance from the face of the surface the wheel mates with to the centre of the disc itself, then this is around 27mm (they're very corroded)
The centre of the disc is recessed, i.e. imagine it like a top hat, the surface of the disc facing outwards is outboard of the bit that joins the disc to the hub (i'm so technical lol)
Posted 5th Aug 2014 at 13:12
Chr1sch
Here's a pic...
Posted 5th Aug 2014 at 13:40
jamiek_uk2000
That is unusual. I've never seen a disc like that before
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 5th Aug 2014 at 13:53
Niall
Errr that pad looks like it's hanging out! I've currently got them calipers and use Volvo 240 pads and they aren't like that!
Posted 5th Aug 2014 at 14:16
Chr1sch
oh crap ok, thanks for the heads up, i did think it looked odd!!
What discs are you using? i feel royally stuck and the brakes are frankly useless
Posted 5th Aug 2014 at 14:38
looks like 406 coupe discs, would be 305x28 and zero offset nearly.
Posted 5th Aug 2014 at 14:41
Chr1sch
305 certainly rings true thank you! i've just checked the pads (they're yellow stuff ones) and they seem to be seated ok?
Posted 5th Aug 2014 at 15:02
Niall
I'm using standard 283mm discs so not the same as yours. Have the pads got the locating pins through the top of them? Just look like they aren't in properly but could just be different pads which also fit.
Posted 5th Aug 2014 at 15:06
Chr1sch
well looking at this: http://c4owners.org/plugins/content/content.php?content.16
I think the previous owner might be right, looks very similar to the C4 VTR/VTS brake disc...
Posted 5th Aug 2014 at 15:21
jamiek_uk2000
Check out the details compared to what your discs are, failing that take one disc to an auto spares shop and compare.
See if you can borrow a digital caliper to ensure measurements are correct
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 5th Aug 2014 at 15:31
many discs will appear similar, measure them as accurately as possible, not forgetting to take into account wear and corrosion buildup.
Posted 5th Aug 2014 at 15:42
Chr1sch
agreed, i foolishly thought they would follow a 'standard'
Posted 5th Aug 2014 at 15:44
jamiek_uk2000
Fool of a took
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 5th Aug 2014 at 15:46
jamiek_uk2000
The only rule is they are round and phillipm tried to change that
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 5th Aug 2014 at 15:59
Audi changed that on the RS4/6 too.
Posted 5th Aug 2014 at 18:24
jamiek_uk2000
Indeed they did.
Copying from motorbikes I believe
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 5th Aug 2014 at 19:21
