Specs are:
M10x1.5
80mm length
35mm top threaded
Remainder as a larger (M12) shoulder
Is that doable?
Rallye Race Car
| Author | Subject: Custom bolt - where to get? |
demondriverdan
I want to get a new bolt made up for my top mount but not sure where I can get it done?Specs are: M10x1.5 80mm length 35mm top threaded Remainder as a larger (M12) shoulder Is that doable? ________________________________________ Rallye Race Car |
M12 bolt turned down and re threaded? Found this place that could help, but your batch size is going make it pricey no doubt ![]() http://www.nationalbolt.com/custom-bolts-fasteners.html ________________________________________ ![]() |
guess you mean a sleeve nut?give dave at satchel engineering a shout, he might know of or be able to make you one. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
demondriverdan
Don't think I want a sleeve nut? Dan's right in that it's essentially an M12x1.5 bolt with the threaded part turned down to an M10x1.5.The mount uses a threaded M10x1.5 bolt at the moment but the hole it goes through is much bigger which I don't like, there's too much room for movement. I thought if I can get a bolt with a shoulder that's bigger that the thread, it should create a nice fit. ________________________________________ Rallye Race Car |
tvrfan007
Seasoned Pro Location: In the garage Registered: 29 May 2005 Posts: 3,488 Status: Offline |
Any local engineering firm could make that for you.________________________________________ I'm Si btw![]() Night Blue VW Golf GTD Bianca LBSC Rallye - Track/Road Slag Project Thread Sparkling Silver Mini Cooper D - Super Dooper - (The other half's wheels) |
front struts dont use bolts, its a nut onto a threaded spindle ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Slide some steel/ally tube over the M10 bolt to take up the slop.________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
demondriverdan
Top engine mount, I should have said, sorry WP!I'll ask around, cheers guys. ________________________________________ Rallye Race Car |
What about the steel tube that's used to mount the steering rack to the subframe? That's M10 I think. ________________________________________ ![]() |
still not understanding which bit you want ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
demondriverdan
dangti6 wrote: What about the steel tube that's used to mount the steering rack to the subframe? That's M10 I think. Good point, might be too think but I'll take one out of the spare car and have a look. ________________________________________ Rallye Race Car |
demondriverdan
welshpug! wrote: still not understanding which bit you want ![]() Vibratechnics top engine mount, y'know the one on the left hand side of the engine with the bridge across? ________________________________________ Rallye Race Car |
demondriverdan wrote: dangti6 wrote: What about the steel tube that's used to mount the steering rack to the subframe? That's M10 I think. Good point, might be too think but I'll take one out of the spare car and have a look. To save you the effort, I've one in my box of 'fixings you keep for a situation exactly like this' which I can measure for you if you like. ________________________________________ ![]() |
ohhhhh, do they not have a stud like a proper engine mount?________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
demondriverdan
dangti6 wrote: demondriverdan wrote: dangti6 wrote: What about the steel tube that's used to mount the steering rack to the subframe? That's M10 I think. Good point, might be too think but I'll take one out of the spare car and have a look. To save you the effort, I've one in my box of 'fixings you keep for a situation exactly like this' which I can measure for you if you like. That would be great, thanks! Saves me taking the rack of the car for no real reason. Not much left on it anyway! ![]() ________________________________________ Rallye Race Car |
demondriverdan
welshpug! wrote: ohhhhh, do they not have a stud like a proper engine mount? Not really, I'll try and describe it as I can't find an exploded picture of one online. The mount is in two pieces. The bottom piece is essentially a case for the top part with a bolt through it that goes down in to the chassis. The top piece has a central bolt that goes through several bits of rubber and comes out of the top for the bridge to the engine to bolt down on to. The top-ward bolt sheared during the last race and I've replaced it with an identical one but would like to get a stronger one in. Just to be sure, there's no fault with the Vibratechnics mount that caused it to shear. My chassis point was pretty badly damaged before going and the mount was moving around a lot. I think with the amount of movement it put undue stress on the bolt and it sheared. I should also point out I'm not running the race mount, just fast road, as it's what came on my spare car and I hadn't thought about it until now! Vibratechnics have been great and helping me figure out what happened! ![]() ________________________________________ Rallye Race Car |
allanallen
Seasoned Pro Location: Buxton Registered: 01 May 2007 Posts: 1,399 Status: Offline |
Mail me a sketch if you want one making up dan. Sounds like the easiest/cheapest way would be to get/make a bit of thin wall tube to sleeve an m10 bolt up to size.________________________________________ www.bridgecraftmotorsport.co.uk |
