Author Subject: Anyone ever had solid beam mounts come loose?
jammapic
Hi,
I fitted some phillipm rear beam mounts around April time, since then I have been to the ring, done a couple of track days and done a few miles on the road... I noticed a clunk from the rear the other day, so have jacked it up to investigate.
Strangely, both sides on the small beam mount have come loose - so much so there's a visible gap between the beam and the body.
Now, before you say it - yes they were torqued up and yes they were threadlocked.
I did wonder when I fitted them if they could potentially vibrate loose with no damping.
JP
HDI Engine Tuning / Remapping Services - https://www.facebook.com/dervtech
306 GTi-6 Track Car - 200+ hp all N/A!
306 DTurbo Track beasty - 209.9hp - RIP
Posted 17th Jul 2014 at 18:55
pugheaven
Have you checked that the studs haven't sheared as Iirc this has happened before
Posted 17th Jul 2014 at 19:07
jeffers Forum Admin
+1 for checking the studs for shearing... Happened to me too!
Team Running Engine again!
Team Negative Camber!
Posted 17th Jul 2014 at 19:32
jammapic
Hmm, that doesn't sound very good... I'll go out and have a look in a bit. It's on the small cylindrical one nearest the back of the car rather than the big strong looking one with 2 studs at the front.
JP
Posted 18th Jul 2014 at 08:43
pugheaven
Yep it's normally the aft ones as they are offset studs
Posted 18th Jul 2014 at 08:49
i've had the studs snap twice in the past. welded them back up, a week later they snapped. welded them again a bit better and they were ok but i heard they'd broke again at some point for the next owner
mine were BBM ones
Posted 18th Jul 2014 at 08:50
Rubber mounrs ftw Big grin
Check the front ones are intact.
Posted 18th Jul 2014 at 11:31
monty-69
mine were BBM ones
Thats shocking, they need to be removed from sale
Posted 19th Jul 2014 at 09:21
monty-69
mine were BBM ones
No studs in the rear of mine, they're bolted into the ally Smile
Posted 19th Jul 2014 at 11:41
