displaying posts 1 to 25 of 217
Pages (9): [1] 2 3 .. last
Author Subject: 2014 High Boost project
pete-gti
Hi guys , well as most of you no I am running low boost rotrex supercharger on my gti6 , for a while been talking about going high boost , well can now say I have in my hands new built high boost engine from lynx engineering , also high boost map and even bigger injectors.
Its not going be done in 5 minutes still need sort out bigger intercooler pipes and fmic , need bigger exhaust bore about 2.5" , uprated clutch , LSD , etc , so needed to invest in these aswell , but least its underway :-) keep close watch on this :-)
Spec so far
Wossner Forged Alloy Low Compression Pistons / PEC Forged con-rod package ACL Heavy Duty Big End Bearings ACL Heavy Duty Main Bearings Thrust Bearings [0118 F4] Crankshaft Oil Seal [cambelt end] [0326 22] Crankshaft Oil Seal [flywheel end] [0127 28] Lynx Power Engineering MLS head gasket & bolt set - stainless core, spring-steel out layers, individual fire rings Timing Belt Kit inc. All Tensioners [0831 48] Waterpump [1201 A1] Seal for Oil Drain Cover [Flywheel End] [0147 12] End Bearing Cap Seals [0127 05] Camshaft Oil Seals [0236 44] Oil Cooler Seal [1104 24] Thermostat Housing Gasket [1340 33] Thermostat Gasket [1340 48] Oil Filter [1109 T0] Inlet Manifold Gasket [0349 G1] Exhaust Manifold Gasket [0349 F4] Valve Stem Oil Seals [0956 38] Exhaust Manifold Studs [0355 68] Exhaust Manifold Nuts [0341 22] Oil pump sprocket - later single-piece type [0513 78] Oil pump sprocket 'O' ring [0514 92] Oil Pump Chain [1033 10] Autojoint AJ66 Sealant for sump, cam carriers etc [9731 AR] Graphogen Assemembly Paste [protects bearings on first start up until oil system primes, won't run off like oil]
Cylinder Block Boring/Honing [diamond hone, plateau finish] Cylinder Block Decking [to clean up gasket face] Crankshaft Journal Inspection / Polishing Cylinder Head Skimming Re-cut all Valve Seats [SERDI 3 angle], and re-grind all Valves to suit K-Lining of worn Valve Guides [to restore to original internal diameter] Reconditioning of Oil Pump
Posted 13th Aug 2014 at 18:49
pete-gti
Posted 16th Jul 2014 at 19:12
RetroPug
Shiny! Smile
Posted 16th Jul 2014 at 19:42
aaron6
I'm still surprised I never see this car about. Looking good so far. Smile
Posted 17th Jul 2014 at 21:55
Good effort Smile
Been wanting to do the same to mine for a while, but the finances just dont allow it at the minute, or any time soon to be fair Laugh
Posted 18th Jul 2014 at 09:05
pete-gti
Hi guys and girls little update , I have now started to strip old engine out , going be a slow progress but its going be well worth it :-) , my engine crane be here Friday , took few pictures of stripping engine down as I always like to show you lot step by step action
Looms out
So hopefully by Friday engine will be out :-) then can give engine bay good clean etc few bits can get painted . Will keep you all updated:-)
Posted 13th Aug 2014 at 17:46
Tarmac terror
What injectors are they....Injector Dynamics???
TT
Posted 13th Aug 2014 at 22:45
pete-gti
Siemens 660cc high impedence injectors
Posted 14th Aug 2014 at 00:03
russbez
very nice, I wish my block to looked like that!
good luck
My Rallye project thread
Posted 14th Aug 2014 at 08:40
pete-gti
UPDATE well engine is now out , demon driver nearly cut off my hand off when I said its for sale ( lovely lock up mate would love something like that)
... been ordering up new parts , gearbox seals , drive shaft seals , gaskets etc, blue hoses , list goes on hit bank balance hard lol, new wishbones and ball joints going to order today
I'm after few engine brackets to be powder coated anyone no of any places near me give me shout :-)
Posted 30th Sep 2014 at 13:31
demondriverdan
It made sense since you're local! Don't think it's moved since you dropped it off but it's on the list of things to get done, will start stripping it down soon.
I also need to get some stuff powder coated, let me know if you find somewhere.
Rallye Race Car
Posted 30th Sep 2014 at 13:41
steve h gti-6
What did you use/do to the head to get that lovely finish ? Looking good fella !
"Gotta Love The 6"
According to my wife i think the 6 is the fastest car in the world, perhaps she is right LoL !
Posted 30th Sep 2014 at 16:22
pete-gti
Bought the rebuilt engine from rich w , came painted :-)
Posted 30th Sep 2014 at 20:43
pete-gti
Got few bits back from the powder coaters , well happy deff going to make things look fresher under the bonnet :-) ,
Posted 22nd Oct 2014 at 22:22
7057sam
New engine looks great
Oh how i'd love another supercharged one
Team rallye,built for track
Rallye dead Sad
Secret Team Astor...
Posted 22nd Oct 2014 at 23:14
pete-gti
Can't wait for the finish product :-)
Posted 23rd Oct 2014 at 14:17
pete-gti
Few little front end goodies , plus my lighter alternator pulley and crank pulley come today :-) cheers rich
.wishbones plus ball joints
.track rod ends
.drop links
Posted 23rd Oct 2014 at 16:57
pete-gti
Fitted top engine mount and few brackets to engine today. , I'm really happy with it , only thing letting it down is the oil cooler needs spraying up so that be coming off soon :-) , also gear box got its first coat today , fork arm is getting replaced with new so want be staying silver , hopefully weekend engine be can started to be put back in:-)
Posted 24th Oct 2014 at 16:14
pete-gti
Fitted my lighter alternator pulley today from spoox Motorsport :-)
Also fitted new wishbones and ball joints and track rod ends and drop links, so little more progress today :-) , can't make my mind up if to get new drive shafts or not mmmm ?
Posted 25th Oct 2014 at 18:40
rallyestyle
Tidy Thumbs up
How much would new driveshafts set you back anyhow?
Just Drive It
Posted 26th Oct 2014 at 21:05
pete-gti
Had a day in garage doing bit more , decided to clean up the SC bracket and Sc , as they where really dirty , happy with the out come Smile. Then fitted charger to engine , just waiting for my LSD to turn up now and need to sort clutch out , I'm hoping box will be on by end of week ...
Still got to clean up that oil cooler only thing letting engine down
Posted 27th Oct 2014 at 17:42
pete-gti
:-) My Quaife ATB Helical LSD Differential turned up today , ( hit the old bank account hard ) but couldn't not buy one or car wouldn't be drive able. Feels shame you to box it up and never see it again lol , new bearings should be here tomorrow get this fitted into box over weekend
Posted 30th Oct 2014 at 17:55
pete-gti
Fitted quaife LSD this weekend into the box , fitted new bearings and seals Smile also fitted new fork and bearings and fork arm, used the old crown wheel bolts , nothing wrong with them so didn't see need to get new ones , just need to order helix clutch kit now , then get box fitted back onto engine Smile
LSD locked away never to be seen again lol
Posted 2nd Nov 2014 at 16:05
ahhh I have spotted the difference with the diff bearings, you appear to have a plastic cage, originals are steel, that'll be why they were a lot cheaper.
Posted 2nd Nov 2014 at 16:15
pete-gti
The ones I have fitted are SKF JL69345F310Q Are dearer then the first ones I bought , 23 pound each these cost, was told skf jl 69345f310q is the part number I needed
Posted 2nd Nov 2014 at 18:22
