what's the TPS throttle position sensor?
if so where is that? is it the sensor not in the pic mounted into the throttle body?
| Author | Subject: misfire |
3gan
Regular Location: Bristol Registered: 28 Mar 2013 Posts: 173 Status: Offline |
Post #51
pardon me for being thickwhat's the TPS throttle position sensor? if so where is that? is it the sensor not in the pic mounted into the throttle body? |
Post #52
Tps is under Neath the throttle body, air temp sensor is a small grey sensor on the back of the throttle body |
3gan
Post #53
so what is at the side of the throttle body?facing the front of the car throttle heater? or is mine just mounted different? |
RetroPug
Post #54
Yes throttle body heater is the yellow thing on the front. That won't affect running really, only useful on very cold winter mornings.TPS is Throttle Position Sensor, on the bottom of the throttle body. Should be able to feel it if you stick your hand under. ________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
Post #55
Yellow thing ? Has something to do with fuel vapour I think but it does not a lot in my eyes |
3gan
Post #56
I have read up tons of threadstested what I think are all ok sensors anyone recommend a lambda please as I think it could either be that or map sensor :-) |
3gan
Post #57
Ok people updateFriend coming round later with diagnostic equipment Took for a spin was almost like it was overfueling and missing then picking up as you accelerate, had a short run then trip on motorway gritted teeth lol So seems ok when on full chat, makes me think lambda as its getting very hot then and not functioning well when just part throttle when its cooler Place your bets |
3gan
Post #58
question for you guysif my lambda was faulty would it trigger the engine management light? could it be a bad earth somewhere? cheers lee |
3gan
Post #59
update peopletried the link below and have 5v at the plug but when wiring it up and testing the map sensor using the 3 wires it's staying at around 5v there is no voltage change so I guess this is the problem my sensor does not react anything like the video have ordered a second hand one see what happens if it works I'll post up cheers lee http://www.pugaddicts.co.uk/2014/02/map-sensor-testing-with-a-multimeter.html?m=1 |
Post #60
I'm now going to test mine & The Lambda sensor ...just in case ...do have some tick over probs sometimes ....good info |
3gan
Post #61
let me know how you get onsounds like yours in throttle position sensor |
3gan
Post #62
ok new Bosch sensor fittedwhen cold or just started when warm drives fine then after a couple mins Boggs down again anyone have any ideas water temp sensor? air temp sensor? |
3gan
Post #63
No more misfireLambda sensor was faulty! So if you get similar symptoms unplug it and if its no good the car will drive fine |
