Author Subject: Rear brake adjustment
cornish_pug
Car failed MOT today on rear brake efficiency, it needs new pads too. They said something about adjusting the cable out to the stops of the caliper to get the best out of them. Can anyone shed some light on this please.
Team Diesel
Posted 23rd Jun 2014 at 22:54
jord294
If you have a compensator, it may be seized
Posted 24th Jun 2014 at 00:12
cornish_pug
Where is the location of it?
Team Diesel
Posted 24th Jun 2014 at 01:24
jord294
You can't miss it if you have one.
It's fastened to the o/s crossmember support, with 4 pipes coming out of it
Posted 24th Jun 2014 at 01:34
Where's that WD40/water pump plier image when you need it.
  • Posted 24th Jun 2014 at 09:42
    scotzman
    Here
    Posted 24th Jun 2014 at 09:47
    cornish_pug
    What's the adjustment up to the stops all about as the MOT tester said
    Team Diesel
    Posted 24th Jun 2014 at 11:04
    scotzman
    Dunno
    Posted 24th Jun 2014 at 11:27
    cornish_pug
    Lol he said make sure I fully slacken the handbrake adjuster then pump the peddle and make sure the cable stops are right up against the arm. No idea what he's on about either.
    Team Diesel
    Posted 24th Jun 2014 at 11:57
    I do, he means the handbrake cable inner swaged fitting, slacken the cables off, mash the pedal ( after freeing the load compensator) so the rear pistons self adjust, then take up the slack in the cables.
    Posted 24th Jun 2014 at 13:10
    bennn
    Rather than just tighten the cable up like most idiots do.
    Cherry Red 306 HDI
    Posted 24th Jun 2014 at 13:57
    Thumbs up
    Posted 24th Jun 2014 at 14:20
    midlife
    scotzman wrote:
    Here
    Your welcomeThumbs up
    Nice to see my artwork is appreciatedLOL
    Cool
    Team 330™Cool
    Team "no front end or engine"
    Posted 4th Jul 2014 at 22:04
