displaying posts 101 to 104 of 104
Pages (5): first .. 3 4 [5]
Author Subject: Carbon, fibreglass and other goodies
fatlapit
Post #101
Any strut braces about
Posted 27th Apr 2015 at 20:23
demondriverdan
Post #102
daveyboy wrote:
I'd guess more negative camber, more tyre in contact with the ground when cornering hence more grip.
That's what I was thinking but I've already got camber adjustable top mounts so wasn't sure if these would help. I wonder if they might reduce bump steer a bit.
Rallye Race Car
Posted 28th Apr 2015 at 00:00
midlife
Post #103
If used in conjunction with adjustable top mounts you can also increase track & still have adjustability or if you don't have coil overs & adjustable top mounts you can still have negative camber.
Also I was told to push them forward to give extra castor
Sorry the strut brace went earlySad
Cool
Team 330™Cool
Team "no front end or engine"
Posted 28th Apr 2015 at 20:38
midlife
Post #104
A few bits for sale
Various bonnet pins & bonnet pin recesses £6.50 per pack delivered
Fibreglass spotlight pod £65 plus postage
Fibreglass lower lamp pods, off Bono's maxi, one is undamaged fitted & with a Hella Rallye 2000 driving lamp (£90 new), the other is damaged but will easily repair with fibreglass & filler, these are rare bloody rare!!, I'd say including the spotlight£140 plus delivery
An example of what they could look like fitted
2 x 20mm hub centric spacers including extra long bolts £50 delivered
Electric fire extinguisher, it's well out of date so can't be used for Motorsport but would be fine for track days etc, there is a pin missing on the control box socket but it shouldn't be too much of a problem to fix or replace, £70 plus postage
Upright hydraulic handbrake new with Wilwood cylinder, £85 plus postage
Varley red top 25 battery £75 plus postage
1 x Competition T pull, 3m long, £10 delivered
2 x 50 LED 52mm MSA approved rain lights, £15 each delivered
Powerflex rear beam tensioners, £9 delivered
Facet 40107 solid state competition fuel pump with filter & pipe fittings, ideal for lifting fuel from the tank to a swirl pot, £30 delivered
Sytec Motorsport high pressure fuel filter, £20 delivered
Ideal for in between your high pressure pump & your fuel rail.
5 metres of 5/16" / 8mm cloth braided fuel pipe, £12 delivered
20off stainless rubber lipped fuel pipe clips, suit pipe above, £15 delivered
20off proper stainless fuel pipe clips, suit above, £12 delivered
Alloy 1ltr fuel swirl pot, push on fittings, suit above, £45 delivered
More to come
Cool
Team 330™Cool
Posted 29th Apr 2015 at 20:52
