Author Subject: Rounded off flexi hose nut
Markie
Hi guy's, got a bit of a problem. In trying to remove the front flexi hose, the nut that joins to the hard line has rounded off. Angry I soaked it in penetrating oil and wire brushed the hell out of it for the past two weeks! I first tried a proper brake spanner, then mole grips and now it's f'd. Sad I haven't twisted the brake line though, not sure what to do now, really don't want to have to replace the whole line.
Any help would be greatly appreciated.
Thanks.
Posted 6th May 2014 at 15:22
chiefton
Is it a front line? If so they join just up inside the chassis leg if you follow it under/see from underneath they are short then join the main lines!
cherry rallye daily (the money pit)
Posted 6th May 2014 at 15:33
Markie
Yeah it's the front line drivers side the bit where the arched bracket thingy is, so i should hopefully just have to replace a short length of brake line? If so can i get it pre-formed from peugeot? Sorry for the newbie questions, this is my first time doing this!
Thanks
Posted 6th May 2014 at 15:41
chiefton
Im not sure about pre formed. If you ask a local garage they probably have the right stuff just to knock it up quick or if you have a brake pipe flarer you can do yourself so easy,I had to do when I fitted ross's massive brembos as he had same problem!! Very easy fix dont panic!!
Posted 6th May 2014 at 15:45
Markie
Just had a look and followed the brake line up and there's a join in the engine bay, do i just remove it from the join in the engine bay and cut it off by the flexi hose join? Then take it to a garage and get a new one made up to the same length?
Thanks again.
Posted 6th May 2014 at 15:51
chiefton
Yep exactly that,maybe make just a few mm longer to compensate where you cut it but any garage should be able to knock it up if you take it with you.
Posted 6th May 2014 at 15:59
Markie
Nice one thank you! Now to see if the other side will come off. Wink I only wanted to change the discs and pads and have ended up replacing and rebuilding the calipers, new flexi hoses and noticed there's a split in the driveshaft boot! Oh well, it'll be worth it.
Posted 6th May 2014 at 16:09
chiefton
Ah the joy of a "small job" always turning into greater. Welcome to the wonderful world working on peugeots mate LOL
Posted 6th May 2014 at 16:16
jamiek_uk2000
When I did mine I used a set of small stillson's, 8" I think I used, they are awesome for any rounded off nuts. You can get a set on Ebay for about a tenner and they always have a use.
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 6th May 2014 at 18:56
Markie
I'll give it a try on the other side Thumbs up I thought the mole grips would do it but they just chewed the nut!
Posted 6th May 2014 at 19:47
6waysforward
Another vote for stillson's if you have a rounded off nut etc.
Posted 6th May 2014 at 19:49
oldbrownshoe
I had this problem 2 years ago, i had to cut out from the metal hos side,
so i had to replace all the line to the pump end,
then i couldn't insert the new line, it's path was too twisty so i had an idea,
went to a hose shop and asked them to cut the metal hose to 3 parts, flare it
and install the adapters, after that is was easy to connect the parts.
old
new
zoom out
French military victories?
Did you mean French military defeats?
Posted 10th May 2014 at 08:20
oldbrownshoe
If you can get the brake line with the much more sturdier 14mm nut (instead of the 13mm)
it won't round off so easily.
Posted 10th May 2014 at 08:28
