Author Subject: negative camber rear beam
pugheaven
Due to me going wide track on the dimma I no longer need this beam, it was rebuilt using oem bearings etc a week before rich sold the car so has probsbly only covered 4k miles if that, the trailing arms were machined to give -3 degrees of camber at the same time and were provided by bridgecraft engineering
This beam makes such a difference on track, however not brilliant for a road car as it makes the car follow the contour of the roads (still drivable tho)
The beam will come with the 21mm torsion bars that are currently fitted, I will be removing my solid mounts, hybrid anti roll bar and the powder coated brackets, I have the standard brackets to put back on so all you will need is an arb and some mounts
The beam will be available from the end of the month (due to me still being away) so you have time to save a little for it Thumbs up
The tb's are worth £100ish and the negative camber arms would probably sell for the same if not a little more, the beam tube is powdercoated yellow (a few lityle scratches on it) could probably sell for £30
Ill sell the lot for £300
Posted 2nd May 2014 at 16:28
Phil white
I'll take the negative arms if you struggle to shift the entire beam. No need for the rest of it. Cheers.
Posted 2nd May 2014 at 16:39
pugheaven
Na im not going to split it, if it doesnt sell ill keep hold of it as im bound to buy another pug at some point lol
Posted 2nd May 2014 at 16:41
Phil white
Ok mate. No problem.
Posted 2nd May 2014 at 16:43
allanallen
Bargain that Wink
Facebook
Posted 2nd May 2014 at 18:03
jeffers Forum Admin
That is a bargain, I rebuilt mine using gen new bearings and neg camber arms new wheel bearings etc etc and it cost a lot more than that plus the time that went into it! Decent upgrades for the track boys I can vouch for that! Works real well with a 30mm arb! Good luck with the sale.
*Edit* I drove mine on the road with the above set up and it doesn't follow the road as much as you may think it's a very worthwhile upgrade for a car that maybe does a bit of both, track and road.
Team Running Engine again!
Team Negative Camber!
Posted 2nd May 2014 at 19:04
t3ora
Must not buy
Must not buy
Must not buy
Must not buy
Must not buy
Must not buy
Must not buy
Road/track car coming together slowly
Posted 2nd May 2014 at 19:26
jeffers Forum Admin
t3ora wrote:
Must not buy
Must not buy
Must not buy
Must not buy
Must not buy
Must not buy
Must not buy
Decent upgrade, get it bought! Big grin
Posted 2nd May 2014 at 19:29
roberts_306
tempting
www.pugsport-racing.co.uk
Posted 2nd May 2014 at 21:48
Carl Chambers
roberts_306 wrote:
tempting
get it bought Dave, if you don't I might as want the neg camber arms!
Carl Chambers
email; pugnacious.peugeot@yahoo.co.uk
C.M.CHAMBERS CARS
Peugeot Specialist
Tel; 01379 586101 after 6.30 or 07889 082466 anytime.
Posted 3rd May 2014 at 08:29
roberts_306
Ok I will take it for £300 let me know how I can pay
Posted 3rd May 2014 at 13:24
pugheaven
Dont worry about payment yet, pay when you collect it bud
Posted 3rd May 2014 at 14:31
roberts_306
Ok when shall I be able to collect
Posted 3rd May 2014 at 15:45
pugheaven
End of may bud, gives me a few days once im back to remove it and swap the bits over
Posted 3rd May 2014 at 17:54
roberts_306
Cool I've got a race at brands hatch on 1st June so could pick up either before or after
Posted 4th May 2014 at 20:23
pugheaven
Any time/day will be fine with me
Posted 5th May 2014 at 09:56
