Author Subject: Rattle at 3k (now 4k) Revs - Heatshield?
MY95
So, I get a rattle at 3k (now 4k) revs at idle, is this a heatshield or something?
Posted 3rd May 2014 at 19:53
heatshield or could be cat breaking up if you have one. had this on my HDI the other month and it was the innards of the cat
Posted 1st May 2014 at 19:54
MY95
Thought it could have been the cat too, hope not, cheers for the info
Posted 1st May 2014 at 19:57
just take it off, beat the insides out, refit. diy decat done in 30mins
Posted 1st May 2014 at 20:03
MY95
Not when its a petrol, and youve got to get into it by cutting then get someone to weld it back up, may as well get a new one for a bit more, fair enough on a HDI but not a petrol
Posted 1st May 2014 at 20:05
RetroPug
I'd suggest jacking the car up and shaking the exhaust at various points and seeing where it hits a heatshield or which bit has rattly insides.
Posted 1st May 2014 at 21:55
MY95
Thats a great idea, thanks very much Smile
Posted 1st May 2014 at 21:59
It might be the same issue as mine, My exhaust cam covers heatshield isnt on as the thread is ******.
Replacing my exhaust cam cover on the weekend
Posted 2nd May 2014 at 10:27
MY95
Checked exhaust this afternoon, no rattles, pretty smokey when revving it to 3k in neutral - cat stuffed?
Posted 2nd May 2014 at 17:46
MY95
Could be, where is it located so I can check mine? cheers
6waysforward
coil pack cover bolts Yes
Posted 2nd May 2014 at 18:03
MY95
Thanks for the info, will have a look when i get a chance Smile
Posted 2nd May 2014 at 22:26
Is this rattle present when engine is cold ?
Posted 2nd May 2014 at 23:14
MY95
It is, after just being started up
Posted 3rd May 2014 at 08:43
MY95
Its not the coil pack cover bolts 6waysforward as ive tightened all but one of them fully up (the other tightened up 3/4 of the way and didnt want to turn any further) and the rattle is still there at 4k now
Posted 3rd May 2014 at 17:41
6waysforward
Oh well, worth a shot.
It happened to me a few years ago and i had the car on a ramp 3 times to find it. It was only by chance i noticed one or two of the cpc bolts were loose causing the cover to vibrate and sound like a headshield rattle.
Posted 3rd May 2014 at 19:26
MY95
Oh right, thanks for the guidance anyway! Smile
I have an idea its the heatshield if its went from being heard at 3k to 4k now, sounds the most logical
Posted 3rd May 2014 at 19:51
scotzman
My heatshield used to vibrate, I checked the bolts and they were all tight, I then slackened them off slightly, wiggled it about a bit and retightened, noise gone Smile
Posted 3rd May 2014 at 19:59
MY95
Cheers, which heatshield as I had a look on servicebox before and there were many? Smile
Posted 3rd May 2014 at 20:13
scotzman
The one that bolts to the exhaust cam cover.
Posted 3rd May 2014 at 20:16
MY95
cheers! which ones that on the diagram? http://public.servicebox.peugeot.com/docapv/affiche.do?ref=N5A117H10A&refaff=N5A%201%2017H10A&idFct=FCT0512
Posted 3rd May 2014 at 22:54
Have you checked the exhaust isn't too close to any of the heat shields under the car ? Check the cat as well as aftermarket cats usually are a poor design at sit close to the heat shield
Posted 4th May 2014 at 00:59
Had this many times with a 6 engine usually either the heat shield behind the cam cover as said or it's the fire ring between the manifold and down pipe that's warn down causing a terrible noise at about 4K.
If your under the car you'd think it was the cat falling to bits but it's only the big round seal in the joint before the cat gone.
Posted 4th May 2014 at 07:48
MY95
Thanks guys
I havent checked it bigbadbowen yet so thats to do, cat looks pretty newish so theres another thing to check
I will also have to check that armzs16 haha, easy enough to spot on servicebox and cheap to replace if shot?
Posted 4th May 2014 at 09:39
