Author Subject: 12 inch radiator fan
devere
I am shortly going to have a 12 inch fan off my previous rad setup This was a nice fit on my 306 nissens rad.
I have changed to a different rad now and this is too big. I bought it from CBS last year I believe it was. And it hasn't really done much work as the car has barely moved. When it has been in use, it works perfectly, and brings temperatures down very quickly.
I would take it off as carefully as possible and include the fitting kit, including the push through the rad parts, which could be reused. But just so there is no confusion, the fitting kit is used
To buy it from CBS would be 73 pounds delivered. Anyone want this one for say, 50 delivered?
Posted 1st Apr 2014 at 22:38
jamiek_uk2000
Is that a pull fan. Iirc the expansion is on the left as you look at it?
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 2nd Apr 2014 at 17:36
devere
It was used as a pull fan yes.
It can be used either a push or pull. You can swap it round quite simply, to work either way.
Posted 2nd Apr 2014 at 17:47
devere
Up.
Posted 7th Apr 2014 at 20:49
devere
Bump, Offers?
Bin day early next week and I need to move stuff that is no use any more!
Posted 5th Jun 2014 at 21:26
fatlapit
How thick is it??
Posted 5th Jun 2014 at 21:35
devere
fatlapit wrote:
How thick is it??
Surprisingly clever for a rad fan actually..... Whistle
On a more serious note, il go measure it in a second.
Posted 5th Jun 2014 at 21:38
devere
At its widest point, in the very centre, it is 2 and a half inches thick. it then sits another 1/4 of an inch off the rad due to the rubber pads it uses to sit against the radiator fins.
Posted 5th Jun 2014 at 21:45
Do you reckon two of these would fit a nissens?
Posted 13th Jun 2014 at 12:12
devere
I am not there to measure at the moment. But from looking at it I would say yes.
I personally ran this and a 10 inch on the other side. That was for clearance issues to something tho.
I would say you could either get 2 side by side. Or one front and one back, both 12 inches.
Posted 13th Jun 2014 at 12:34
Rallyman
I would be interested in this if you still have it - could it keep up with cooling on stages?
Posted 15th Jun 2014 at 21:49
devere
I used it with a 10 inch fan on the other side. I always have 2 fans in case one packs up. I have never had any problems with this cooling the engine though,
Ive just moved to a shorter radiator, so need a 2nd 10 inch fan now as this is too big for my rad.
Posted 15th Jun 2014 at 22:23
