Is there anyone around Brighton who has the appropriate tool to pop them out for me??
Rallye-RNurburgring article
| Author | Subject: Torsion bar removing tool |
braymond
Seasoned Pro Location: Brighton Registered: 20 Aug 2008 Posts: 1,163 Status: Offline |
I’ve got a pair of 24mm torsion bars which, I suspect still hold a bit of value. However they’re still very much located in whatever it is they locate in (hub?) Is there anyone around Brighton who has the appropriate tool to pop them out for me?? ________________________________________ Rallye-RNurburgring article |
Capt Pedantic Location: Bigend, Wales. Registered: 27 Mar 2007 Posts: 25,868 Status: Offline |
![]() are they stuck in the trailing arm or the crossmember? ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
braymond
Trailing arm I would guess. The bars are separate from each other, but each have a lump of car on one end.________________________________________ Rallye-RNurburgring article |
![]() or ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
braymond
I did try to tickle them out with option 1, but to no avail. As for option 2 - I'll check again but I don't think I spotted on in the shed. Am I wrong in think there is a tool for this then? Is just about accurate deployment of brute force? ________________________________________ Rallye-RNurburgring article |
if they are that stuck a puller tool wont do the trick, as its only an M8 thread.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
braymond
I see. Best buy a can of spinach on my way home then..________________________________________ Rallye-RNurburgring article |
I'd just lob them in the boot and find a friendly garage.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
bennn
Seasoned Pro Location: Shrewsbury Registered: 05 Sep 2008 Posts: 2,705 Status: Offline |
I used a big socket, a bolt with a nut on it and some big thick washers to wind mine out.That did the trick for me. Like this Socket Method ________________________________________ Cherry Red 306 HDIChampionship White Integra DC5 Type R |
demondriverdan
One of the best things we found was to put the beam on it's end and put a load of WD40 all over it and inside the ARB is it runs down and through. Next day it came apart much easier.________________________________________ Rallye Race Car |
aaron6
still relies on the M8 thread, so still limited severely on properly stuck bars ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
aaron6
True, but should free most. ![]() ________________________________________ See the sheer power and might of the lesser known burrowing owl. |
jamiek_uk2000
Well if they are aftermarket bars the beam has been apart so SHOULDN'T be as stuck.If you break them, I'm not buying them mind lol ________________________________________ 205 GTi Red - G939 RTU - Died!306 GTi 6 Diablo - Being resurrected! Project Thread Looking for: VTS P1 Rack PR1.2 16" |
braymond
jamiek_uk2000 wrote: Well if they are aftermarket bars the beam has been apart so SHOULDN'T be as stuck. If you break them, I'm not buying them mind lol Haha Fair! I'll keep you posted... ________________________________________ Rallye-RNurburgring article |
I can get them out for you buddy.________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
braymond
daveyboy wrote: I can get them out for you buddy. Tres bein! I'll give you a buzz when I'm next over your way. ________________________________________ Rallye-RNurburgring article |
