Author Subject: Car has been laid up
gilesy
And sorned for about 6 months. Any good ideas to get her back to feeling good?
Posted 20th Mar 2014 at 18:15
Give it some compliments, buy it flowers etc.
Posted 20th Mar 2014 at 18:16
calibra306
Mine has been aswell. Ive always started it every week and let it warm up and put heaters blowing on.
Im on the verge of putting her back 100% for putting back on the road.
ive put new wheels and tyres on
im gonna flush and do an oil change inc filters.
Also took battery off for a full recharge.
im gonna change rear discs and pads and probably fluid change ie brake fluid.
V6 Power!
Faster I can go the better!
Posted 20th Mar 2014 at 18:39
gretsch-drummer
^I've read its best to just leave it and not start it/let it idle every weekend.....All I've done it taken battery off and put it on a trickler. Will be on the road this month after 3 month SORN.
Ph1 Cossack 6'
Posted 20th Mar 2014 at 18:48
Idling constantly can cause the bores to glaze not to mention engine wear occurs mostly when cold so starting it once from cold every week doesn't do it good really. Always take the battery off, leve something absorbent inside the car like rice, don't leave the handbrake on.
Once it's been sat a while before starting it for the first time unplug the injectors and crank it over for a minute or 2 to et some oil pressure up and flowing nicely around the engine. Then start it up.
Posted 20th Mar 2014 at 20:24
scotzman
My lawn mower has been laid up for about 6 months and started up just fine the other day LOL
Posted 20th Mar 2014 at 20:29
Is it for sale?
  • Posted 20th Mar 2014 at 20:51
    jamiek_uk2000
    dangti6 wrote:
    Is it for sale?
    The lawnmower or the car?
    Looking for:
    VTS P1 Rack
    PR1.2 16"
    Posted 20th Mar 2014 at 20:57
    anything. he buys anything. if it's for sale, it's his
    Posted 20th Mar 2014 at 21:10
    Pretty much this. Yes
    I turn the engine by hand every two weeks as opposed to starting it. Also, when it comes to starting it whip out the plugs too when cranking for a min or two. The reason for this is because that way as there is no compression, the load on the bottom end bearings is significantly reduced whilst they have no oil. Then once the oil pressure light goes out (normally after 30 secs of cranking) plug the injectors back in, put the plugs in and fire her up. Thumbs up
    Posted 20th Mar 2014 at 23:28
    oldbrownshoe
    Try ten years like mien for real frustration.
    French military victories?
    Did you mean French military defeats?
    Posted 21st Mar 2014 at 00:23
    If you can be arsed taking the plugs out then yes it's worth doing Wink
    Posted 21st Mar 2014 at 12:34
    Ed_van_dijk
    scrap it
    Astor 6
    Posted 21st Mar 2014 at 12:50
    mik
    Some good tips here - in the interests of making the engine last a bit longer I'll take some of this advice in future.
    When I de-SORNed and started mine a few weeks ago I just cranked it a bit and turned it off before it caught a few times to get some oil moving before starting it properly which probably didn't have the full effect.
    Although I stored it with handbrake off, and I pushed the car back and forth a couple of feet every week or so to keep the brakes un-seized and to stop the tyres getting flat spotted.
    Cherry Rallye SOLD
    Posted 21st Mar 2014 at 19:24
    I would say it's critical if the engine hasn't had oil in the bearings for a while, not whether you can be arsed or not Pete...LOL
    Posted 21st Mar 2014 at 20:12
    gretsch-drummer
    So looks like I'll be whipping the plugs out and cranking for a good few seconds before starting next week, been stood for 3 months.
    Ph1 Cossack 6'
    Posted 22nd Mar 2014 at 18:05
    Thumbs up
    I did this today in fact when I fired up my GSXR1000, first time since September. Cool
    Posted 22nd Mar 2014 at 23:11
    gretsch-drummer
    Is it worth unplugging the injectors as well?
    Ph1 Cossack 6'
    Posted 23rd Mar 2014 at 17:01
    Yes
    That way you won't flood the cylinders at the same time.
    Posted 23rd Mar 2014 at 17:05
    gilesy
    I ignored all the above advice and it started first go
    Posted 23rd Mar 2014 at 17:20
    Laugh
    Should we expect anything less from you though?
    Posted 23rd Mar 2014 at 23:48
    gilesy
    As I have a P1, I just neglected to put my pin number in so it turned over without me needing to take the plugs out...
    Posted 24th Mar 2014 at 00:21
    No it will turn over without you needing to disconnect the injectors. Will stop those and the plugs from firing but will still be under compression with plugs in.
    Posted 25th Mar 2014 at 14:06
    not like the engine will be drained totally of oil unless its a fully fresh build.
    Posted 25th Mar 2014 at 14:58
    pin number FTW they're the best part of the p1's
    Posted 25th Mar 2014 at 15:00
