BEWARE it has has the B-post upper mounting points removed as I was fitting it with a full interior and never intended to do competition.
Sprayed in Ford Graphite Grey, I will supply a can of this with the cage for you to tidy up the small bits of damage caused by removing it.
It will be supplied with high tensile mounting bolts and nuts, front floor plates with captive nuts, the foam and omp sleeves you see below. You will need to make 3 mounting points inside your car, these are not supplied but I'm told they are available separately.
£350 collected from Bromsgrove, Worcestershire.
Would much rather have it collected but if you are far away then PM me and I can look into it.
carlosw828
