displaying posts 1 to 25 of 36
Author Subject: KENT PT82 CAMS
morgan205
I have for sale a pair of pt82 cams in good condition.
£270 delivered
morgan205 has attached the following image:
Posted 19th Feb 2014 at 21:14
eddy_gti6
Can you post up pics of the end of the shafts with cam numbers please mate
Posted 19th Feb 2014 at 21:27
morgan205
ok I will go and take a pic
Posted 19th Feb 2014 at 21:30
eddy_gti6
Thumbs up
Posted 19th Feb 2014 at 21:34
dcc
I've seen these. They're well worth it Chris
205 GTI
Xsara HDI
eddy_gti6
Something to replace my catcam 3107s. On building my spare engine back up as the one I get off cjm is down on compression and its definatley not 195bhp as was told.
Posted 19th Feb 2014 at 21:35
morgan205
can just about make out the pt82 bit
Posted 19th Feb 2014 at 21:45
eddy_gti6
Did you run these with standard pistons? Very interested mate
Posted 19th Feb 2014 at 21:46
jeffers Forum Admin
If PT81's require a deeper pocket in the pistons, these will likely need forged pistons.....
Team Running Engine again!
Team Negative Camber!
Posted 19th Feb 2014 at 21:49
morgan205
I ran these with standard pistons with the piston valve cut out machined a bit for clearance. With a standard L+B bottom end, a good ported and polished head and jenveys they made 219 bhp
Posted 19th Feb 2014 at 21:53
jeffers Forum Admin
PT81,
Applications Sports ' R '
Power Band 2500-7000
Cam Lift(mm) 10.94mm Inlet/Exhaust
Valve Lift(mm) 10.94mm Inlet/Exhaust
Duration 264 Deg Inlet/Exhaust
Timing 20/64 64/20
Full Lift Inlet 110 Deg ATDC/Exh 110 Deg BTDC
VC (mm) 0.00mm Inlet/Exhaust
LTDC 1.65mm Inlet/ 1.40mm Exhaust
PT82
Applications Competition
Power Band 3000-7200
Cam Lift(mm) 11.04mm Inlet/Exhaust
Valve Lift(mm) 11.04mm Inlet/Exhaust
Duration 278 Deg Inlet/Exhaust
Timing 31/67 67/31
Full Lift Inlet 108 Deg ATDC/Exh 108 Deg BTDC
LTDC 2.03mm Inlet/Exhaust
I'd say no chance on standard pistons! No
jeffers Forum Admin
Where they timed on standard marks? Or set up properly?
Posted 19th Feb 2014 at 21:54
morgan205
Well Brett sims motorsport built it and it was running brilliant for 3 years until i upgraded my engine and it was definitely on standard pistons with valve cut out enlarged. I would say forged pistons would be better but that's up to the builder
Posted 19th Feb 2014 at 21:59
eddy_gti6
No good if i need Pocketed pistons. Dont plan to spend fortunes on the engine at the minute. My catcam 3107s i know are close with more lift and duration to pt81 what run on standard pistons...
Posted 19th Feb 2014 at 22:02
morgan205
I think bridgecraft engineering machine standard gti6 pistons for £100 a set and off you go
Posted 19th Feb 2014 at 22:04
jeffers Forum Admin
Fair enough. Don't think I'm having a crack at you, I just am very aware how little clearance there is in these engines for cams with a bigger lift than standard even with a pocketed piston! Out of curiosity how much deeper was the piston pocket machined? Mine have had 1mm taken out which I am led to believe is the maximum safely permitted, even then it's damn close with PT81's, I'm sure if Brett built it, they were timed correctly so I'll now shut up lol! Thumbs up
jeffers Forum Admin
Ah if Martin and Allan machined them it'll be a 1mm cutout! Thumbs up
Posted 19th Feb 2014 at 22:06
morgan205
no worries at all, im not sure how much they were pocketed to be honest.
Posted 19th Feb 2014 at 22:08
jeffers Forum Admin
They won't do more than 1mm as I recall as the piston crown Is too thin!
Posted 19th Feb 2014 at 22:10
pete_rallye
If anyones interested in these, I will soon be selling my Omega forged pistons, standard 86mm bore, and nice big valve cut outs. Drop us a pm if interested!
Lap of the 'ring
gman
Glad I didn't buy that engine now!!
1992 Onyx Black 205 GTI-6
2005 Honda S2000 (Sold)
2002 Audi S3 (Sold)
2005 Clio 182 Trophy (sold)
Posted 19th Feb 2014 at 22:12
tom_g205
You have a PM :-)
205 GTi-6 every day motor
205 GTi-6 weekend/track car - project 230 N/A fingers crossed.
Posted 20th Feb 2014 at 07:18
+1
Posted 20th Feb 2014 at 20:36
allanallen
Unless you specify less we pocket 6 pistons by a further 1mm on both inlet and outlet. We'd do it deeper if you wanted but I really wouldn't recommend it, the crowns are really thin as it is! -1mm is fairly proven to be safe.
Facebook
Posted 20th Feb 2014 at 20:49
markylee
Hi Allan it looks like I might be sending you some pistons in the near future then, how much do you charge
Posted 20th Feb 2014 at 21:15
