Author Subject: Electric / relocated power steering setup
jammapic
Well,
That didn't last long. These cars are £&&£?!g horrible with no PAS.
Has anyone got a full PAS relocation kit, or electric power steering setup available? This is a feature I really need to re-instate...
JP
HDI Engine Tuning / Remapping Services - https://www.facebook.com/dervtech
306 GTi-6 Track Car - 200+ hp all N/A!
306 DTurbo Track beasty - 209.9hp - RIP
Posted 7th Feb 2014 at 10:11
I never unstood why on earth anyone would want to get rid of it anyway!
:p
Posted 7th Feb 2014 at 10:27
Niall
Yeah i drove mine less than a mile yesterday before deciding todays job would be to fit my EPAS.
I picked up my pump from the local breakers for £20. Will need to extend the low pressure hose (although this is very cheap) and may have to have the high pressure hose modified depending on where your fitting it. Mine is going down roughly where the air con compressor was and Pirtek have quoted me £5 to cut the original metal pipe from the high pressure hose and crimp on the one that i got with the pump.
Posted 7th Feb 2014 at 10:47
jammapic
Ah, cool. I'll have a look at that Niall... It's no good, is it?! Razz ERROR.
JP
Posted 7th Feb 2014 at 11:17
jamiek_uk2000
Its a better feel when driving with no PAS, people want the feel of a 205 from the steering then realise they are too much of a pussy Smile
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 7th Feb 2014 at 11:32
jammapic
Much better, but it is SO heavy.. Heavier than any 205 I've ever driven.
Posted 7th Feb 2014 at 11:35
Did you change the top mounts as well as remove the p/ s??
the top mounts are different on none p/s ones, makes then run different caster, with the p/s top mounts it will be stiff as f**k.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 7th Feb 2014 at 11:52
jammapic
No, I didn't... just left everything the same and ripped the PAS off so I could get an air box on the throttle bodies.
How much difference does it actually make though? As it stands at the moment, it's so heavy I'm not sure I could catch a slide if it went...
Posted 7th Feb 2014 at 12:59
allanallen
Non pas top mounts have less caster so FFS don't change them!
Facebook
Posted 7th Feb 2014 at 13:10
jammapic
Wouldn't that make it lighter though? As I see it, the stock PAS top mounts have 3.5* positive caster, and the non-PAS ones have 2*. Less jacking effort surely will make it lighter?
Or AllanAllen, are you saying it will drive s**t?
JP
Posted 7th Feb 2014 at 13:15
allanallen
The way I see it more caster will make it more difficult to turn, at shallow angles like the 306 runs the difference may well be fairly negligible. I've never driven a non pas equipped 306 but I'm guessing they also had slower racks fitted?
Re-fit the pas Razz
Facebook
Posted 7th Feb 2014 at 13:25
jammapic
It's looking likely that's the way forward... it's f**king horrible - honestly.
Posted 7th Feb 2014 at 13:26
devere
This isn't having a go at you for taking it off, but I never understand why people can't fit an air box with the steering pump there? I fitted a maxi type air box with the standard pump in place...? Or were you using a dome filter type job?
You can always check ebay for the 106 pas pump. Usually plenty of them on there from breakers.
Posted 7th Feb 2014 at 13:47
Have you double checked the top mount bearings are still fine too?
If the grease goes dry in them you need to be Popeye with no-PAS, you don't even notice with it as the shuttle valve compensates.
Posted 7th Feb 2014 at 13:49
Re-fit the pas Razz
It makes a bit of difference, the non-PAS models had a 3.9 turn rack, which is nice an light so long as you don't mind the feeling of driving a container ship.
Posted 7th Feb 2014 at 13:52
