Wish me luck guys as i have nearly £6k in this engine so hopefully should get a decent power run.
206 Rallycross GTI6 SC SHB 425 BHP clutch eater !!!
| Author | Subject: Super high boost SC |
Hawkesfire
Regular Location: Stockton on tees Registered: 26 Mar 2013 Posts: 180 Status: Offline |
Seasoned Pro Location: Parts for Sale section Registered: 04 Dec 2007 Posts: 7,442 Status: Offline |
Good luck ![]() Anything different from the normal C38 setup? ________________________________________ Chris1999 China Gti6 Supercharged [Fun car] >>Project Thread<<2000 Bianca 306 Diesel [Work runabout] |
gman
Seasoned Pro Location: Didcot Registered: 25 Oct 2007 Posts: 1,471 Status: Offline |
Good luck!________________________________________ 1992 Onyx Black 205 GTI-62005 Honda S2000 (Sold) 2002 Audi S3 (Sold) 2005 Clio 182 Trophy (sold) |
Hawkesfire
No not really has dry sump system etc and rad in the rear of the car________________________________________ 206 Rallycross GTI6 SC SHB 425 BHP clutch eater !!! |
pete-gti
Seasoned Pro Location: Kent Registered: 15 Feb 2009 Posts: 1,297 Status: Offline |
Good luck mate :-) |
jamiek_uk2000
Should be good to see. Shame its in the wrong pug though ![]() ________________________________________ 205 GTi Red - G939 RTU - Died!306 GTi 6 Diablo - Being resurrected! Project Thread Looking for: VTS P1 Rack PR1.2 16" |
rallyeash
Good luck, I get nervous about engine mapping at RR's.________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
Seasoned Pro Location: Southwark Registered: 18 Jul 2010 Posts: 4,865 Status: Offline |
Is it a gti6 engine or a ew i forget?________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
rallyestyle
Seasoned Pro Location: London Registered: 23 Jul 2003 Posts: 14,991 Status: Offline |
I think it is a 6 engine ![]() I go to Stckton a few times a yeasr for business Hawkesfire, might have to track you down for a passenger ride next time im there ________________________________________ Just Drive It |
stan_306gti6
Good luck mate, you'll love it!Is Wayne doing the mapping, or someone else? ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
gman
I thought you had to go stand alone if going super HB?________________________________________ 1992 Onyx Black 205 GTI-62005 Honda S2000 (Sold) 2002 Audi S3 (Sold) 2005 Clio 182 Trophy (sold) |
stan_306gti6
gman wrote: I thought you had to go stand alone if going super HB? ![]() You do, but Wayne still mapped my DTA S60 Pro for me. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Hawkesfire
Hi AllNot the best result engine is running great and new rear rad set up works great but we are only getting 18 psi boost at 6800 rpm giving us 300 bhp at the wheels so something is not right although i only have a 6 rib belt on a I am struggling to get a 8 rib due to the dry sump set up so it could be belt slippage at high boost but we are Also get extremely hot manifold bright red and the same with the exhaust so we are thinking we are getting a restriction there ? What manifolds are being used on the other High boost conversion and what size exhaust I have a 2.5 inch fitted? Also need to check the can timing and make sure we have no boost leaks around the injectors as I thought I would have 22-25 psi boost Looking to build a new 4 " exhaust tomorrow but unsure about the manifold ?? Any thoughts ?? ________________________________________ 206 Rallycross GTI6 SC SHB 425 BHP clutch eater !!! |
pete-gti
How much did you make at the fly? |
Hawkesfire
Hi was just over 350 at the fly ________________________________________ 206 Rallycross GTI6 SC SHB 425 BHP clutch eater !!! |
pete-gti
50bhp lost , I lost 41 bhp from fly to wheel, not to much difference I no I'm running low boost, does seem bit under power for high boost, what compression you running? |
Normal for the manifold maybe. I remember seeing a few pictures of RichW's car on the rollers when around 400bhp and the manifold was glowing purple/red. Although thinking about it, think that was when he was running about 500bhp ![]() Hopefully Stan or another high boost owner can confirm. ________________________________________ Chris1999 China Gti6 Supercharged [Fun car] >>Project Thread<<2000 Bianca 306 Diesel [Work runabout] |
Hawkesfire
Bit of an update I checked the cam timing and the exhaust cam was 1/2 hole out so have reset it and then set about with a spray of soapy water trying to find any leaks Found the dump valve to be leaking when boost came on so removed it as was not too keen on this any way and never ran one with the C30 Checked round the injectors to the manifold and it was passing round here on all of them so new seals and a dab of silicone as well just to make sure as they are not that tight fit to the manifold. Just thinking about why the exhaust is getting so hot and i think it may be they way the Omex was set up originally as they have the fuel of the tps and the ign off the boost which on a turbo car you would run both the fuel and ign of the bosst to ensure correct fueling so this could be why the fuel is getting pushed in via the TPS position but there is little boost for it to need it ? Anyone else running an stand alone ecu that can advise or comment? I have e-mailed Omex for there comment so will update once i hear from them. ________________________________________ 206 Rallycross GTI6 SC SHB 425 BHP clutch eater !!! |
pete-gti
Least you spotted the timing was out :-) , you proberly notice it go better now?, didn't bend any valves did it? |
gman
Is your throttle body on the inlet or charger?________________________________________ 1992 Onyx Black 205 GTI-62005 Honda S2000 (Sold) 2002 Audi S3 (Sold) 2005 Clio 182 Trophy (sold) |
stan_306gti6
Marty, you need the dump valve on the super high boost as the throttle body is in a different location and the pipe work is setup is the same way as a turbo which is why you need it. ![]() You have other issues there than just an exhaust issue. My manifold didn't glow on the rollers being mapped, and mine made over 450bhp easily. It was done by lunchtime, with just a few tweaks from Rich's map. 350bhp at the flywheel on this setup is very wrong, you're like 100bhp down on what you should be. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
pete-gti
Compression test it :-) |
stan_306gti6
pete-gti wrote: Compression test it :-) Remember for a SHB engine, the pistons should be changed to make 8:1 CR instead of the HB's 9:1. ![]() I assume you've done this during the engine build Marty? Also, out of interest, why did you choose to go with Omex as opposed to the tried and tested DTA setup? ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Hawkesfire
Hi StanCr is 8.1 and went with Omex cause it's what I had on my old car After speaking with Omex I think we might have a solution that has been overlooked on the mapping as I questioned the TPS controlling the fuelling but there is also a fuel boost correction map hidden on the system that might not have been changed on the rolling road set up but I am waiting to speak to the guy at the rolling road. I have tried to contact Wayne to set up my car but have got no Responce via email from him yet as I am working in the USA this week but will try calling him tomorrow have you a mobile number for him ? Marty ________________________________________ 206 Rallycross GTI6 SC SHB 425 BHP clutch eater !!! |
07874 328306 as far as I know though I've never spoken to him yet he's a very busy man apparently lolAnd I'd be expecting to make min of 350 at the fly with a c30 setup so you have a serious issue somewhere. If the manifold Is that hot without a turbo then you may be running to lean which is really not good! Boost leaks an timing sorted should help a lot though. Would have thought you'd have heard te belt slipping if that was the case? Rich W also recently made a 6 rib setup for the C38 so it must be possible to use that rather than 8. ________________________________________ Black power baby! SUUUUUPERCHARGED Seat Leon FR TDI 190BHP 300lbft daily gti-6 killer :p 12x 306's owned so far Cambelts, clutches, service work carried out on All makes and models, Peugeot Citroen / mitsubishi specialist. Pug planet / Citroen Lexia diagnostics / code reads available. |
