displaying posts 1 to 25 of 38
Author Subject: Oil Cooler Setup
eddy_gti6
Any pics would be helpful as to where and how is the place for an oilcooler and where to plumb the lines? Got mine to fit at some point today or tomorrow.
Posted 26th Jan 2014 at 02:31
blandy
This is where I had mine
Posted 26th Jan 2014 at 10:17
mark.evs
I got in touch with a company on e-bay and had 2 40inch pipes made and they fit perfect. I modified the bumper and mounted the oil cooler to it giving plenty of room for the fans. Also cut the bottom off the number plate too.
My GTi6 track project
White Rallye project
Posted 26th Jan 2014 at 10:20
eddy_gti6
Need to move my oil cooler as I need to bring my rad forward to the other side of the slam panel to make room for my inlet. Will the oil cooler be fine behind the rad or even behind the top grill between the headlights if I can make it fit?
Posted 7th May 2014 at 09:58
it'll be fine behind.
Posted 7th May 2014 at 10:10
aaron6
ust fitted mine. Works well here. Bit tight with the normal fans.
Posted 7th May 2014 at 10:18
eddy_gti6
Good good. I will just stick it behind the rad then. Should be plenty room for it.
Posted 7th May 2014 at 10:22
aaron6
There will be if you use slim lines? I still had standard and had to just whittle a little of tue grill away with a dremmel.
Posted 7th May 2014 at 10:31
pugheaven
Dont have any pictures but on Rich's old car the oil cooler was behind the drivers side fog light (bolted to the drivers side slam panel with brackets) I would suggest mounting it there rather than behind the rad
Posted 7th May 2014 at 11:12
aaron6
dunno. They look good in the middle
Posted 7th May 2014 at 13:09
eddy_gti6
I am already using a slim line fan but as said above my radiator needs to come forward to the front of the slam panel and pretty much hard up against the bumper to make room for the VLR inlet.
If you could find some pics ollie that would be ideal.
Here is why I need to move my rad forward.
Posted 7th May 2014 at 13:39
pugheaven
Take it your just going to pivot the top forward and leave the bootom where it is so then you dont have to mess around with the bottom rad hose?
Dont think I have any pics mate Thumbs down
Posted 7th May 2014 at 14:32
eddy_gti6
No moving the whole lot forward mate
Posted 7th May 2014 at 14:55
aaron6
Christ thats a big inlet.
Posted 7th May 2014 at 19:23
eddy_gti6
Sure is. Too big for the engine bay Laugh my ass off
Posted 7th May 2014 at 20:58
Niall
Dont mock the boost piping. It was just a mock up lol
Posted 7th May 2014 at 21:02
jamiek_uk2000
Don't lie, I bet that's how it it still is now Big grin
It all gets a bit tight once you put the boost into it, where is the charge cooler in all that setup?
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 7th May 2014 at 21:07
Niall
haha nah im a pikey but not that much!
Charge cooler? Don't have one! This isn't a rotrex setup Wink
Posted 7th May 2014 at 21:30
aaron6
Does that jump about niall? The mounting plates look a bit thin.
Posted 10th May 2014 at 07:57
jamiek_uk2000
No I know its not boosted. Mine will be though so I'm planning my space!
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 10th May 2014 at 08:02
aaron6
n the charged ones I've seen the oil cooler behind the fog light and the charger cooler on top of the intercooler.
Something like this.
Posted 10th May 2014 at 09:00
Niall
Not at all. It's 2mm steel plate and for the most of it, they sit on the cross member.
It is boosted. Just not with a rotrex Smile
You could do what I've done, mount the cooler off to one side then the charge cooler on the other side.
Posted 10th May 2014 at 09:10
eddy_gti6
Been thinking about this since you mentioned it, might actually give it a try, may save welding a new cross member on and could mean I wont have to move my oil cooler Thumbs up
Posted 10th May 2014 at 11:00
pugheaven
Im not as stupid as I look Wink
Posted 10th May 2014 at 11:46
eddy_gti6
Just not sure it will fit between the headlights looking at some pics? Can only just try
Posted 10th May 2014 at 11:48
