displaying posts 26 to 38 of 38
Pages (2): 1 [2]
Author Subject: Oil Cooler Setup
would work if you used a 205 rad.
Posted 10th May 2014 at 12:05
eddy_gti6
Then that means piping in a header tank. If I was to fit a header I would probably run a R5 turbo alloy rad. Will allow more room for oil cooler ect...
Posted 10th May 2014 at 12:53
Chr1sch
This is going to sound really thick but where do the pipes go?
Do they literally just run from the cooler to the stat and back? My car has the cooler fitted but the stat is in my boot...what causes/propels water to flow etc?!
Posted 5th Sep 2014 at 16:07
Chr1sch
Ok help! Finally got the car on stands and can see how/where the stat goes, what's not clear is the filter? Does the stat replace what looks like a fairly large collar already ok there or do the filters come with a long enough thread to pass through the stat and still go into the block?
I've yet to take the filter off (only done 2 k since changed last)....
Finally, previous owner said it's running 5w/40, does that sound right?
Cheers!!
Posted 14th Sep 2014 at 07:30
aaron6
My thermostatic sandwich plate bolted to the oil filter mounting using a piece supplied with the kit, then the filter screwed onto that.
Posted 14th Sep 2014 at 07:47
aaron6
Posted 14th Sep 2014 at 08:04
Chr1sch
Ah crap, thanks
I have a Mocal one that looks very similar to yours, but I don't have anything to fix it to the block with? Literally the stat housing and pipe work?
(It came with the car... So don't know if something has been lost?)
The pipe work I have is push fit rubber too,most seem to use braided, is there a reason for this?
Cheers!!
Posted 14th Sep 2014 at 09:48
aaron6
Braided just protects hose from chaffing. Mines a mocal and it came with a little center adaptor. M22 threaded iirc. I'll see if I can find one on the net.
Posted 14th Sep 2014 at 10:08
aaron6
You need the filter adaptor you can see fitted in the center of the sandwich plate. Give mocal a buzz. They should be able to supply one cheap enough. Maybe someone on here has one. I think it's actually M20 threaded, not M22.
Posted 14th Sep 2014 at 10:34
Niall
Post #35
Mocal sell the bolt on its own for about £2.50. Should be able to find it on Ebay. Thats where i got mine from
Posted 14th Sep 2014 at 10:38
aaron6
Post #36
There ya go. Smile
I think it's this
http://pages.ebay.com/link/?nav=item.view&id=400742019613&alt=web
Posted 14th Sep 2014 at 11:02
Chr1sch
Post #37
Fantastic thank you!!!
Posted 14th Sep 2014 at 22:30
cully
Post #38
i fitted mine behind the std rad fan in front of the rad cooler is bolted to the lower cross-member
Posted 15th Sep 2014 at 10:31
Pages (2): 1 [2]
