Author Subject: SOLD AP Racing CP8351 calipers
jorg
got these posted on the 205 forum so i might as well post them here too.
I have for sale a pair of unused AP Racing CP8351 4 pot calipers still in the box with two sets of pads.
AP Racing link: http://www.apracing.com/product_details/race_car/brake_calipers/rally_range/4_piston-r2_or_similar_series-%C3%B844.5/%C3%B847.6mm_bores-cp8351.aspx
Piston sizes: 44.5 x 2 and 47.625 x 2
Pad Area ( cm³ ): 66.67
Radial mount, 152 x 40.8mm centres.
Suits Ø285 or Ø310mm x 26mm discs.
Lightweight Forged Aluminium alloy construction.
Stainless steel pistons.
High temperature, low drag seals fitted as standard.
Manufactured with bleedscrew and pipe protection.
Stainless steel pad abutments and wear plates fitted
Weight: 2.04kg (without pads)
also included are two sets of brake pads, these again are both new and unused in boxes. these will require a slight mod to one of the bridgebolt holes on one of the backing plates in order for the retaining bolt to it.
the pads compounds are:
Carbone Lorraine RC6
Ferodo DS2.11
the calipers use the same shape pad as wilwood superlites so loads of compounds are available.
I am looking for £600 delivered both for the calipers and pads
306 2.1 S16 Tarmac Rally Car
Posted 4th Jul 2014 at 15:36
Maxipug
Would these go under 15" 205 speedlines ?
Mlilley.
205 Gti-6 engine
Bilstein shocks front/rear with Eibach springs
Powerflex poly bushed
Much more to come hopefully...
Posted 24th Jan 2014 at 23:45
calibra306
I very much doubt it prob 17 inch alloy min
V6 Power!
Faster I can go the better!
Posted 24th Jan 2014 at 23:56
jorg
17" min? bit ott for a 285-310 disc size. These will fit inside 15" team dynamics depending on what size rotor you choose Yes
No idea about the 205 speedlines I'm afraid No
Posted 25th Jan 2014 at 07:06
jeffers Forum Admin
I would suspect they won't go under 205 speedlines....
Team Running Engine again!
Team Negative Camber!
Posted 25th Jan 2014 at 07:53
scotzman
These have less clearance than cyclones.
Posted 25th Jan 2014 at 08:02
Maxipug
Ahh that's a shame Sad they are a gorgeous bit of kit !
Mlilley.
205 Gti-6 engine
Posted 25th Jan 2014 at 13:10
jorg
I know its not a 205 speedline but i had a go at fitting these calipers behind a 15" cyclone Ninja
this was mocked up quite quickly so i am no way saying it is perfect. I think if you used a Hi-Spec 283x26 rotor with a 2mm offset custom bell and a 10mm hubcentric spacer then they will fit. It will be close though.
also here is a picture of the pads
Posted 26th Jan 2014 at 16:42
calibra306
The calipers look huge! Lol
I do have 325 discs though ;-)
V6 Power!
Posted 27th Jan 2014 at 03:04
jorg
bump..... was going to keep these but they now need to go
new price of £550 delivered
Posted 21st Mar 2014 at 17:39
jorg
SOLD Big grin
Posted 22nd Mar 2014 at 09:57
