Author Subject: Power steering cooling pipe removal.
Markie
Hi guys, thinking about removing the power steering cooling pipe as it's rotten, i've read somewhere on here that people have cut it out and joined the two pipes up...this is probably a silly question but i'm just wondering what to use to join the two pipes up? Any help would be muchly appreciated. Thanks.
Posted 23rd Jan 2014 at 12:19
One option:
The end of the cooling pipe chopped off.
  • Posted 23rd Jan 2014 at 12:32
    Markie
    Thanks Thumbs up mines too rotten to use but I'm guessing I could use something similar? Copper pipe maybe? Wink cheers.
    Posted 23rd Jan 2014 at 12:50
    eddy_gti6
    It will only be surface rust. Good wire brush on a grinder should sort it out and a lick of paint
    Posted 23rd Jan 2014 at 12:53
    Markie
    I was thinking that but Its weeping in two places, one place being near the u bend, will have a closer look as I might be able to save the ubend.
    Thanks Smile
    Posted 23rd Jan 2014 at 13:09
    jord294
    Iirc, pug heaven on here has an excellent powdercoated one for sale
    Posted 23rd Jan 2014 at 13:01
    cully
    Mine was a little more than surface rust
    But as said I used a bit of the good steel pipe and joined the two return hoses directly under the reservoir,
    The one under the engine mount is flexible enough to bend it through 90, so you only need about 30-40mm of pipe and two hose clips
    Posted 23rd Jan 2014 at 13:05
    Markie
    thanks for the info guys, i'm guessing it would be easier to just bin the cooler than replace it? dangti6, have you noticed any problems since removing it? cheers.
    Posted 23rd Jan 2014 at 15:41
    That's a pic I stole. I don't have powersteering at all as I re shelled into a 205.
  • Posted 23rd Jan 2014 at 16:28
    scotzman
    I did mine a few months ago and haven't noticed any change, much easier than replacing the pipe too.
    Posted 23rd Jan 2014 at 16:50
    scotzman
    Pic of mine
    Posted 23rd Jan 2014 at 17:06
    jimmyhackers
    im gonna make me sound like a dingle here
    but power steering cooling?..... never knew i had it......where does the fluid go to cool?
    what is the mechanism/chamber that actually does the cooling?
    is cooling you PS fluid neccisary?
    Posted 23rd Jan 2014 at 17:15
    scotzman
    The cooling pipe is a big hairpin shaped pipe that runs along the front of the front lower crossmember and is prone to rotting, as for if its needed, ive done without mine for a few months without issue so far.
    Posted 23rd Jan 2014 at 17:25
    Markie
    scotzman wrote:
    Pic of mine
    Have you used a rubber hose to join the two pipes?
    Posted 23rd Jan 2014 at 21:55
    scotzman
    Just jointed the two hoses as they come off the pipe with a plastic garden hose connectorLOL and two clips.
    Markie
    Haha sounds fairly simple!
    Posted 23rd Jan 2014 at 21:59
    cully
    the hard bit is doing it without loosing all the fluid Wink
    Posted 23rd Jan 2014 at 22:15
    Yep, I got rid of mine back in early 2008, never had an issue. Smile
    Posted 23rd Jan 2014 at 22:25
    Markie
    I think all my fluid will have leaked out by the time I get round to sorting mine. Wink
    Posted 23rd Jan 2014 at 22:43
    I need to do this really.
    I assum you have to drian it first?
    Posted 24th Jan 2014 at 09:38
    You don't have to, but it'll get messy if you don't. Yes
    Posted 24th Jan 2014 at 10:13
    RetroPug
    While you're there you might as well replace the PAS fluid.
    Posted 24th Jan 2014 at 10:33
    Clamp the hoses up before undoing the cooling pipe. Use vice grips if you don't have proper hose clamps. You'll lose less fluid then.
  • Posted 24th Jan 2014 at 10:35
    eddy_gti6
    Job on my to do list over the weekend before the new engine goes in.
    Posted 24th Jan 2014 at 11:20
    whats the proper way of draining the fluid then?
    I suppose it needs replacing really. I certainly haent done that yet...
    Posted 24th Jan 2014 at 12:50
