displaying posts 1 to 25 of 49
Author Subject: ITB kit and cam recommendation
hepkem
hi,
I want to upgrade 99 Xsara VTS engine with ITB and don't want to upgrade to solid lifters for now.
I checked the forum but didn't come up with any info about dbilas ITB kit ;
http://www.dbilas-shop.com/Products/Throttle-body-kit/Street/Citroen/Throttle-body-kit-for-Citroen-Peugeot-306-309-405-ZX-Xsara-Xantia-1-8-2-0-16V-XU::234.html
About cams there're several options from pipercams and catcams ;
Piper cam GTI6BP285H - 264/264
http://www.pipercams.co.uk/pipercams/www/product.php?pid=GTI6BP285H
Catcams 4903106 - 267/259
http://catcams.co.uk/acatalog/4903106.pdf
Catcams 4903109 - 274/2567
http://catcams.co.uk/acatalog/4903109.pdf
Which one do you recommend to use with ITB and hydraulic lifters ?
Budget for the engine upgrade is reasy so do you recommend to upgrade to forged pistons and rods while doing this upgrade ? If yes which brand do you recommend ?
Any info from experienced users will be highly appreciated Smile
Car has KW V1 coilover, Hyrid ARB, Quaife LSD, 406 V6 Brembos, Richw Flywheel, poweflex bushes... need a faster engine for Istanbulpark track days Smile
1999 Xsara VTS ITB
Posted 23rd Jan 2014 at 21:18
allanallen
The catcam 'sport' cams are the only ones that will go in a standard (unskimmed head) engine. The others have to much lift at TDC, you'd have to retard them to avoid piston contact which is far from ideal.
You could either deepen the pockets in your standard pistons or as you mention go for aftermarket forged items.
Can't comment on the bodies sorry, never seen nor heard of anyone using them. They look very expensive though?!!
Facebook
Posted 20th Jan 2014 at 17:09
hepkem
hi allanallen, thanks for the reply. dbilas has another kit with cheaper price, for race use they call it ;
http://www.dbilas-shop.com/Products/Throttle-body-kit/for-Racing/Citroen/Mutli-throttle-intake-system-for-racing-for-Citroen-Peugeot-306-309-405-ZX-Xsara-Xantia-1-8-2-0-16V-XU::248.html
I check that Jenvey kits are in the range of 800 pounds so dbilas doesn't seem that expensive.
Is it possible not to skim head and use 4903109 with just aftermarket forged items ?
If yes which brand and which model do you recommend ?
Any weblinks will be highly appreciated.
1999 Xsara VTS ITB
Posted 20th Jan 2014 at 22:14
hepkem
I'm planning to buy wossner piston and forged rods with them while I do these upgrades so GTI6BP285H the right cam or is it better to use PT82 or similar cam while I invest in pistons and rods ?
another question is about is about 92mm crank.
http://www.306gti6.com/forum/showthread.php?id=158487&page=last
is it easy to find compatible rods to use with crank and setup a 2.2 stroker engine or is it too much burden ? do you recommend to stay with itb + forged pistons/rods and pt81/pt82 kind of cams ?
I don't want to run 8K+ rpm so don't want to upgrade to solid lifters.
need help from gurus on the forum, come on Smile
1999 Xsara VTS ITB
Posted 23rd Jan 2014 at 21:25
markylee
Hi, sorry for a little thread hijack, I'm gonna be using jenveys and am gonna pocket the pistons, is there a desired cams to run with this, cheers
Posted 25th Jan 2014 at 10:24
hepkem
np, I hope somebody replies Smile
I plan to use dbilas because it will be more silent with special manifold.
I guess PT81 will be the right choice for both daily and track use and PT82 will be the one to use with pocketed standard pistons and standard rods.
1999 Xsara VTS ITB
Posted 26th Jan 2014 at 16:01
hepkem
dbilas already ordered and hopefully arrive to Istanbul in 1-2 weeks, will start project thread once all the parts are ready.
still waiting for recommendation on cams, anyone ? Smile
1999 Xsara VTS ITB
Posted 28th Jan 2014 at 19:02
paulvancraen
Catcams 4903109
There's a guy in the Netherlands with dbilas and these cams and he makes around 200 bhp
Make sure you know what you're doing when fitting them or you'll end up with bent valves.
Or get some expert to do it for you Wink
Posted 31st Jan 2014 at 09:51
jeffers Forum Admin
If I remember rightly, with pocketed standard pistons kent PT 81's are the ones to use or the cat cams equivalent. The reason being is the crown of the piston will only safely take a 1mm deeper pocket. After that you will almost certainly require high comp forged pistons! There is a thread around somewhere written by welshpug on pistons and clearance etc, il have most round when I'm on the computer rather than my phone later on and post a link! Thumbs up
Team Running Engine again!
Team Negative Camber!
Posted 31st Jan 2014 at 10:05
hepkem
hi guys. Thanks for the replies.
I have discussed the project with pug1off for more than 1 week and placed order for following parts from pug1off ;
87mm Wossner high comp forged pistons and conrod set
catcams 4903110 camshaft, springs, retainers and pulleys
acl big end bearing and acl maing bearings
emerald k6 ecu and 55-pin harness adapter
mocal oil cooler kit
bbm engine mounts, gear linkages, shortshift
Above parts will be delivered probably in 7-10 days. Dbilas ITB was already dispatched from Germany on Tuesday. one of the most professional modding garage will install all the parts and best mapper in Turkey will take care of the software. I guess installation will start in early March and car will be ready in Arpil.
I'll start project thread once the parts arrives.
Hope everything goes as planned and have a reliable and strong engine Smile
1999 Xsara VTS ITB
Posted 6th Feb 2014 at 21:30
edhunter
Hi,
what's going with the project Smile
Have you assembled the engine, is there any measurements - what power it generates Smile
Posted 31st Mar 2015 at 13:45
hepkem
everything has been put together last september. here's the project thread in Turkish ;
http://www.techturkey.com/forum/project-cars/181439-xsara-vts-itb-project.html
How the VTS looks like right now ;
This is how the engine bay looked just before bedding stage with 4K limited map. Original valves created problem during bedding stage so Supertech valves has been installed after sometime, video is before that stage ;
https://www.youtube.com/watch?v=l9G0had4HQU
188ps and 177NM at the wheels and 229ps and 216NM at the crank, measured on Mustang Dyno which is pretty accurate ;
I'll open up a project thread whenever I have some extra time available.
All my videos are on youtube channel. Below is the link of the track day session at Istanbul Park which took place on 12th of April, yesterday Wink
https://www.youtube.com/watch?v=BGR0IAHerOw
1999 Xsara VTS ITB
Posted 13th Apr 2015 at 20:21
hepkem
Hi Guys,
I had a good running car with with following setup before but wanted higher power for Istanbul Park track so decided to upgrade to solid lifter setup with 4903276 cams.
Car had standard manifold before so I have custom built a long tube 4-2-1 headers as new cams will run at 8800rpm max instead for 8200rpm hydraulic setup of 4903110.
4903110 Setup
AT Power Biller 45mmx4 ITB
Reverie Carbon Airbox
87mm 12.2 Compresson Wosnner Pistons
PEC Rods
Catcams 4903110 Cams, Supertech Valves, Catcams Springs
Emerald K6 ECU
4903110 to 4903276 Setup Changes
49903276 Cams with Solid Lifters
Helix Clutch & Stachshift Shifter
4-2-1 Long Tube Headers
Following is the new vs old power grap. Old setup on this specific dyno was 221ps and 211NM and new setup is 216ps and 195NM !
There’s big drop in torque and power curve is worse and less than previous setup ??
I purchased all parts from Pug1off till now and their expected power with this cam setup was in the range of 255-260ps ?
I have discussed with my engine builder garage and they said that 12.2mm compression 87mm wossner pistons could be the reason as this much high profile cams would do better with 13-13.5 higher compression pistons.
Down below is the new exhaust manifold, please share your comments on this one also ;
As quick change I plan to go back to stock manifold and check the power curve again together with ECU tuner.
I’m open to any other suggestion from experienced users
1999 Xsara VTS ITB
Posted 14th Jul 2016 at 16:52
manifold looks reasonable, what are the tube diameters and lengths?
not sure on the compression ratios, what is the duration of the cams?
which inlet manifold? confirm the throttles go to w.o.t, i have heard of issues with at stuff, nice and bling but lacking in the design and testing, you'll be on the limit of 45's with much more than roughly 240 bhp also.
Posted 14th Jul 2016 at 17:57
hepkem
thanks for the reply @welshpug.
Here's the profile link for the cams ;http://catcams.co.uk/acatalog/4903276.pdf
307 / 298° , 13.00 / 12.50mm
It's the highest profile available at Catcams based on the website.
ITB is from Pug1off, AT Power 45mm ;
Used with Reverie carbon airbox and with large diameter intake hose connected to bumper with big trompet air inlet ;
I'll check manifold pipe diameters and length and let you know but here's photo installed on the car ;
1999 Xsara VTS ITB
Posted 14th Jul 2016 at 18:49
pete_rallye
Have you managed to fit those cams with adequate valve>valve clearance? 13:1 compression sounds high for pump fuel to me.
Lap of the 'ring
Posted 14th Jul 2016 at 20:01
hepkem
I have Wossner 12.2 high comp pistons with enough valve clerance. used 95 octane shell pump gas + octane additive which increae octane in the range of 98-100 octanes
1999 Xsara VTS ITB
Posted 14th Jul 2016 at 20:06
pete_rallye
not valve to piston clearance, valve to valve. When you get near 300 degree duration with these heads you'll find the inlet and exhaust valves are very close on overlap. You'll need to be careful with your spring rates/heights etc to ensure you don't get any valve float otherwise the valves will almost certainly hit.
Lap of the 'ring
Posted 14th Jul 2016 at 20:57
hepkem
engine builder set everything up based on cam profile sheet and checked everything twice. I guess we'll understand if we had a problem like that when we remove the head for checking but I want to check all the options before start removing the parts for control.
1999 Xsara VTS ITB
Posted 14th Jul 2016 at 21:10
IvayloPavlov
How much om the wheel is this 216? Are you using standard 5 gearbox? Higher RPM like shorter trumpets,and 4-2-1 increase mid range but 4-1 high.
Posted 14th Jul 2016 at 21:54
only if its the wrong 4-2-1 and a less wrong 4-1
Posted 14th Jul 2016 at 22:00
hepkem
Wossner has 12.2 comp 87mm pistons in production but any higher comp version isn't available.
Does anyone recommend higher comp pistons on this setup and if yes brand and comp ratio please ??
Pug1off told me that trumpet length could be an issue also and recommended shorter trumpets, any ideas??
Is there anybody on the forum with same cams or similar high profile solid lifter setup ??
1999 Xsara VTS ITB
Posted 15th Jul 2016 at 00:42
loads of pistons out there of higher compression once you stop looking at the cheap stuff.
amusingly the better stuff can be cheaper if you find the right application due to numbers produced.
qed do an 87mm omega piston with quite a tall crown and deep valve cutouts, rougly 8mm clearance on standard valves and about 12.5-1 in a 2.2, itll be much higher in a 2044 engine
it does need the valve cutouts modifying on the exhaust a little, but a decent quality piston at about £400 a set iirc.
youll probably need different rods though, on an 86mm crank youll need rougly a 161mm rod.
Posted 15th Jul 2016 at 08:44
hepkem
is wossner cheap stuff ? I have paid 750(w/o tax) pounds for pec rods and wossner piston set.
I don't remember PEC rods length but maybe can find within the papers of the parts I keep.
I can buy new piston set no problem but do you think it will solve my problem and will offer better curve and 25-30ps more than my previous setup ?? if yes where can I source these pistons from ?
I'm not sure if these race cams will offer what I want at the moment Sad
1999 Xsara VTS ITB
Posted 15th Jul 2016 at 08:55
hepkem
@welshpug
do you also recommend shorter trumpets for 307° / 298° solid lifter setup ?
1999 Xsara VTS ITB
Posted 15th Jul 2016 at 08:57
