displaying posts 1 to 25 of 67
Pages (3): [1] 2 3
Author Subject: 6th gear upgrade or gearbox swap
atgti6
Hi all im new to the club and I am looking for some help!
I have a gti 6 and the gearbox ratios are irritating me, is there a 6th gear upgrade to make it longer so I can lower the engine rev in 6th?
OR does anyone know if there is a different gearbox that will fit, that will give me better mpg.
any advice is appreciated!
Thanks
Posted 19th Jan 2014 at 15:55
scotzman
What mpg are you getting?
They don't rev overly high in 6th at motorway cruising speeds.
Posted 19th Jan 2014 at 16:27
atgti6
I'm not really sure about mpg but barely getting 300 miles to a tank, and I'm not driving it hard.
Mine revs at 2750@ 60 in 6th and about 3500@ 70 in 6th. This is a bit excessive for 6th gear
Posted 19th Jan 2014 at 16:44
woody.
Probably your lambda sensor giving up if you're getting poor mpg. Have a search as there's numerous other threads about mpg
Posted 19th Jan 2014 at 16:46
pugheaven
Iirc you can change it for the diesel 5th gear which will go e you around 2k rpm at 70
Posted 19th Jan 2014 at 17:04
atgti6
Kl do you know if the diesel 5th gear will swap straight out? Is that the 5th gear from the 306 2ltr hdi
Posted 19th Jan 2014 at 17:19
pugheaven
So I'm led to believe and yes the hdi one, not sure what you acceleration will be like with it fitted tho
Posted 19th Jan 2014 at 17:41
You have something wrong with your car...Yes
Recently I managed to get 224 miles to the first half of a tank from a fill-up, doing a solid 70 mph on the motorway. As you can see from my signature, my GTi-6 is supercharged running 454bhp. If I can manage that fuel economy on a motorway run then yours should easily do it. Yes
I suspect your lambda sensor is probably giving up the ghost. The ratios in this gearbox are perfectly suited for the road, with 6th being a lovely cruising gear.
Posted 19th Jan 2014 at 17:44
scotzman
Has anyone ever tried that gear conversion? I suspect the engine might be a bit bogged down at those revs at 70 and your MPG probably wouldn't be improved.
As said at constant motorway driving I can get 450+ miles from a tank easily and normal day to day use is 360+.
Posted 19th Jan 2014 at 17:50
pugheaven
I know a few people with gti6 turbo conversions that have changed 6th gear to the hdi 5th, I agree that something is wrongfor you to get poor mpg but lowering the rpm at motorway speeds will always be a good thing!
And Stan driving off "boost" is essentially the same as driving a standard six so you having 454bhp has nothing to do with it.....
Posted 19th Jan 2014 at 17:58
atgti6
Cheers il think about the diesel 5th gear swap out.
I have never got more than 365 miles to a full tank! The gear ratios are too close together, unless you only interested in racing it to max revs. I only use 1st 2nd 4th 6th because 3rd and 5th are too similar to 4th and 6th.
I don't commute on motorways so don't expect to get great mpg.
Posted 19th Jan 2014 at 18:02
atgti6
I hear what your saying about the lambda sensor and Il change that first to see what improvement I get!
Posted 19th Jan 2014 at 18:09
I know, but there is a feeling out there that once charged, regardless of speed they are worse on fuel. I was merely pointing out that that isn't the case.
If anything, mines slightly better than when it was standard. Yes
Posted 19th Jan 2014 at 19:36
JWP EFi
Turbo Legend!
Stan, i don't understand how it can be better on fuel as your on lower compression meaning it would be less efficient, obviously good mapping will help but your also consuming power by driving the charger
Posted 19th Jan 2014 at 22:29
I know what the op means, when your used to other cars that rev low and are silent at 70-80 and you get in a 6 it feels like your revving the absolute tits off it on the motorway, then you look at the rev counter and although it's quite high it's not as
High as it seems.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 19th Jan 2014 at 22:45
Yep, I know exactly what you're saying mate, however the MPG speaks for itself. I was really surprised to get that kind of consumption on a long run I must say as I expected worse, but there you are.
Having said that though, on the same trip I did manage to use 1/3 of a tank to only 28 miles when really playing hard in the French Alps. Laugh
Posted 20th Jan 2014 at 07:31
scotzman
High as it seems.
Should try my 1.6 205 then, around 4K at 70mph and its not the quietestRazz
Posted 20th Jan 2014 at 08:08
m306
High as it seems.
Yeah i agree, the gti6 revs a whole 1000rpm higher at 70 than my megane does.
supercharged China gti6 - Thu 16th Sep 1999 - sold
2010 megane rs250
Posted 20th Jan 2014 at 09:57
superchargedblack1997gti6
Is this a confirmed swap? As the supercharged cars could benefit from this for ultimate top speed?
Can anyone confirm this as having been done ? chers
Posted 20th Jan 2014 at 10:59
pugheaven
Iirc pug performance have done it for a few customers
Posted 20th Jan 2014 at 12:23
Cheers mate just seems like an idea to get done at the same time the straight cut gears go in. no need to use 6th until 140mph anyways so thought this should give a top speed of approx 190?
Posted 20th Jan 2014 at 12:31
High as it seems.
Yep but I just look at it as the characteristics of the car, if we really don't like it then we have the wrong car and should just go get a 6 speed big engined diesel that revs at 2k at 70-80
Posted 20th Jan 2014 at 14:03
Would you really want to do 190 in a 306 though? LOL
Posted 20th Jan 2014 at 14:05
Andy do you actually use the six speed in youres. I think that it would be awesome for mega top speed in our boxs?
Posted 20th Jan 2014 at 14:06
Yes mate use 6th loads, doubt I would if it was that high though
Posted 20th Jan 2014 at 14:34
Pages (3): [1] 2 3
