Please note all prices do not inc postage
Collection of any parts is also welcome and can be collected from Warrington
Parts that are available
Standard 20mm torsion bars £10 each but sold as a pair
Standard 24mm rear arb (no end plates) £10
Half leather seats £75 details here
Door cards £20 details here
Steering wheel - a couple of marks on the top and 92k worth of use on it £20
Clocks with 92,600 miles £10
Wiper stalk £10
N/s drive shaft £10
N/s head light (not crystal) £10 Lower clip missing
O/s head light (not crystal) £10
Alarm siren £10
N/s electric mirror - black bits need a back to blacking, the electrics work £10
Grill £10 details here
Hockey sticks details here
Side repeaters in orange £5 details here
Throttle body to air box pipe - icv pipe connector is in tact too. £10
Left hand electric window switch £5
Thermostat outlet - in tact with clip £5
Front calipers £60 details here
Rear calipers - £40
Steering rack inc ram - needs a new O/s boot as it has a split and inc lower u/j if you want it. £25
Front fog lights - all mounting clips in tact £20 the pair
Gear gaitor £7 posted
Bonnet badge - all mounting clips and bolts in tact £7 posted
Gearbox - Selected gears fine and from the little slow drive I did had no issues. £50
Parts not availble
Engine
Ecu loom
Ecu
Battery box
ABS parts
Rear trailing arms
ARB end plates
Master cylinder
Brake load valve
Boot lock
N/s front wheel arch liner
Wheels
Lambda sensor
Pas parts (not inc steering rack)
Parts that should be available once removed and inspected to make sure they are ok
Front bumper
Willing to listern to offers
marksorrento205
