Author Subject: supercharger ECU
gman
I'm buying a lynx kit that was fitted to a phase 1 gti6, but my engine and loom is from a phase 2 (possibly phase 3).
Does anyone know if fitting the lynx mapped ECU from the phase 1 to my phase 2/3 loom/engine be compatible?
Many thanks
Graham
1992 Onyx Black 205 GTI-6
2005 Honda S2000 (Sold)
2002 Audi S3 (Sold)
2005 Clio 182 Trophy (sold)
Posted 12th Jan 2014 at 21:32
JWP EFi
Turbo Legend!
Never been involved with anything 'charger wise,but PH1,2 and 3 ecus are the same so i would presume it will be plug and play
Posted 12th Jan 2014 at 21:49
Yep, it'll work fine. Yes
The only think you'll need to watch out for is whether it's locked. If it was soft unlocked when it was removed from the Phase 1 then it'll work straight away on yours.
Posted 12th Jan 2014 at 22:00
gman
It is unlocked, but only 'soft' unlocked, with the pins still there supposedly
Thanks for the confirmation tooSmile
2002 Audi S3 (Sold)
Posted 12th Jan 2014 at 23:07
No worries, when you connect it to yours, it will become locked to your car then and work normally.
Posted 13th Jan 2014 at 07:38
spiky
some of the connections will be different
MAF
oil pressure
PAS
MY YouTube Videos'
268+BHP and 860kg = FUN
Posted 13th Jan 2014 at 08:12
rich_w
The connectors on the loom are different, but the ECU's are the same, so they can be swapped around no problem Smile
Contact Details:
07732 822546
Posted 13th Jan 2014 at 09:23
6waysforward
My kit is from a ph1 and went in my ph3 just fine mate. Only difference is the powersteering sensor iirc.
Posted 14th Jan 2014 at 18:00
gman
ok great, so it looks like it should be a straight forward swap bar the powersteering sensor.
Can anyone expand on this part?
Thanks
2002 Audi S3 (Sold)
Posted 14th Jan 2014 at 22:01
Thanks
Are you using a 306 power steering pipe in your 205? If not then you needn't worry.
  • Posted 14th Jan 2014 at 22:06
    6waysforward
    Doh sorry, forgot you were putting it in a 205.
    In that case ignore me.
    Posted 14th Jan 2014 at 22:07
    gman
    Kind of, will be using VTS pipes as I'm running a phase 2 xsara vts rack
    2002 Audi S3 (Sold)
    Posted 15th Jan 2014 at 09:22
    If your PAS sensor plug on the loom differs to the sensor in your pipe, change the sensor over to the matching shape be in square or rounded. It just unscrews from the pipe.
  • Posted 15th Jan 2014 at 10:13
    spiky
    Or the connector on the loom Smile
    MY YouTube Videos'
    Posted 15th Jan 2014 at 10:17
    gman
    Cheers guys!
    2002 Audi S3 (Sold)
    Posted 15th Jan 2014 at 13:03
