Author Subject: Anti roll bars - 205 gti6
Maxipug
Afternoon chaps
I'm looking at getting the 309 22mm front arb for my 205 this week, what's everyone's consensus for the rear ? It's just fast road but looking for a bit more stability!
Cheers guys
Mlilley.
205 Gti-6 engine
Bilstein shocks front/rear with Eibach springs
Powerflex poly bushed
Much more to come hopefully...
Posted 12th Jan 2014 at 17:42
rallyeash
Don't do it!! A 309 front arb will just make it understeer more! Leave the 205 one on the front, get a 24mm 306 gti6 standard arb for peanuts, cut it to 205 length and weld one end plate on.
I did this and cost me nothing as my brother bought a 28mm 306 arb and had a standard one spare.
309 3dr K20 Type R
Posted 12th Jan 2014 at 18:02
Maxipug
Ahh really :/ ?! Even with putting a 306 one on the rear ?? What are you running on your beast ??
Mlilley.
205 Gti-6 engine
Posted 12th Jan 2014 at 19:24
gman
Agreed as suggested. Keep front standard and uprate the rear, along with a set of uprated to torsion bars. I run 24mm arb and 21mm TB, with bilstein group n shocks. Rides great and isn't too stiff
1992 Onyx Black 205 GTI-6
2005 Honda S2000 (Sold)
2002 Audi S3 (Sold)
2005 Clio 182 Trophy (sold)
Posted 13th Jan 2014 at 14:02
beez_neez_gt
Mine has the 309 gti front ARB and 6/VTS machined 24 rear for 205. I had the front fitted before the rear and yes it handled like a dog. Since I fitted the rear 24mm ARB it has totally transformed the whole car, they compliment each other very well indeed and is the best mod that's been done, thus far.
Some like some don't, this means some will say its rubbish and only you will know if it works for you, your driving style and your car, so try not to listen to some.
To try and explain my experience using them, well when I went round a short sharp bend at 70mph the whole car skidded, just a touch and all 4 wheels skidded through the bend, which to me shows how well balanced it is.
Mine has GpA rear mounts
Gp N Bilstein rear shocks
Standard TB's
24mm properly machined 6/VTS 24mm ARB using 205 end plates.
Now fitted with -2 camber
Front
VTS shocks
Eibach 30mm lower springs
Gp N mounts
309 Motaquip bones for some negative camber
Remember mine has the 6 engine fitted as well, so wanted the 309 ARB to compensate for the extra 20kg weight at front.
The key to a good set up is having the rear stiffer than the front and its worked for me very well indeed.
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 13th Jan 2014 at 05:51
spiky
mine was running a 309 front ARB
but as said above, did understeer,
then i fitted a 24mm arb to my 309 rear beam and the handle was perfect again Smile
you cant do one without the other
MY YouTube Videos'
268+BHP and 860kg = FUN
Posted 13th Jan 2014 at 08:11
rallyeash
My opinion however I prefer the smaller 205 arb I'd actually like to go smaller on the front and see how that fairs. A lot of proper race setups don't even runs front arb. That tells you something.
My setup is
Front
309 wishbones
GAZ coilovers
350lb springs ( I think)
205 arb
Adjustable top mounts
Tran X diff
Rear
23mm torsion bars
24mm arb, fitted onto a 205 beam.
I strongly believe also there is no benefit to having a 309 beam on the rear. People think the car handles better for a wider rear track but it is actually the increase in Torsion bar size which comes with the 309 beam.
I think a higher spec'd 205 beam is much nicer. I went from 205 to 309 back to 205 for such reason.
309 3dr K20 Type R
Posted 13th Jan 2014 at 13:49
I've personally gone for a 309 rear because it allows me to use Berlingo 21.3mm torsion bars which are a fair bit cheaper than having 205 length ones made up. Plus I like the look of it with fuller arches. Horses for courses.
  • Posted 24th Jan 2014 at 15:13
    rallyeash
    dangti6 wrote:
    I've personally gone for a 309 rear because it allows me to use Berlingo 23.1mm torsion bars which are a fair bit cheaper than having 205 length ones made up. Plus I like the look of it with fuller arches. Horses for courses.
    Certainly. A 205 looks much better with the wheels sat that bit further out. However I have a s**tty base modelLOL
    309 3dr K20 Type R
    Posted 13th Jan 2014 at 13:57
    alastairh
    Same experience.
    Al
    205 GTI6
    Primera GT
    Xsara VTS
    306 GTI6
    Posted 13th Jan 2014 at 16:50
    allanallen
    23.1mm Berlingo bars? Is that a typo dan?
    Personally not a fan of 309 beams on 205s, they make them feel very dull and ruin turn in for me. I think they look gash too!
    My 309 runs a 205 front arb........Yes Thumbs up
    Facebook
    Posted 13th Jan 2014 at 17:34
    quote:
    oops well spottted LOL
    *21.3
  • Posted 13th Jan 2014 at 18:02
    rallyeash
    How did you find running a thinner arb?
    309 3dr K20 Type R
    Posted 13th Jan 2014 at 19:44
    jord294
    if i ever get another 205 gti, i'm going to try 309 axle with the 21.3mm torsion bars and 25mm arb
    tempted to try one of my spare 309 gti front arbs aswell
    Posted 13th Jan 2014 at 19:49
    miles
    Better off fitting decent width Rim's instead of a manky old 309 beam (Terminology) using them over 6 or 6.5" rims makes a difference in a positive way
    www.pugracing.com
    Posted 13th Jan 2014 at 22:27
    allanallen
    Very little difference really as it's on 500lb springs and big bars
    Facebook
    Posted 13th Jan 2014 at 23:32
    beez_neez_gt
    Agreed with Miles about alloy size, 309 beams on a 205 are gash and as said were only fitted back in the day for cheap bigger bars.
    Also if you want the rear to have the wide look you could always use 306 6 stub pins on the arms and bearings with the ABS ring and that brings them out a fair bit.
    If you need some nylock hard bushes for the rear ARB 205 plates, im selling them for £5 a beam since I got a load cheap.
    Pug fee`ver,
    Posted 24th Jan 2014 at 15:08
    allanallen
    Ahh so after you boned me for advice on various hub and arm set-ups, had me plead with my boss to actually sell you stuff (due to your bad rep on the drivers forum and countless pms advicing me not to deal with you), then insulted me over several pms acusing me of being a time waster! You've gone out and had some arb bushes made?! Brilliant, cheers. Thumbs down
    Facebook
    Posted 25th Jan 2014 at 08:11
    scotzman
    Wider wheels with lower offset fill the arches nicely Smile
    Any opportunity for a picRazz
    Posted 25th Jan 2014 at 19:06
