Author Subject: Wheel Alignment Problems
Fellows
Hi all
Hoping for a little input. I have just had a wheel alignment carried out, and sadly for me, everything but the front camber is out. Not by huge margins, but out nevertheless.
Apparently though, the only adjustment able to be carried out is for the front toe. Is this right (my car is standard Peugeot I should add)?
I remember when changing the front sprigs that there was no adjusters I had to mark up etc, but thought nothing of it at the time.
What are my options here can anyone tell me?
Thanks
Posted 10th Jan 2014 at 15:26
jord294
Perhaps it's had a bump in the past Hmm
Posted 10th Jan 2014 at 15:45
Fellows
Could be, though having looked round it I don't think so. It has done 125000 though...
As I say, nothing is far out. Just a bit out!
Posted 10th Jan 2014 at 15:50
French manufacturing tolences for you Smile
  • Posted 10th Jan 2014 at 15:52
    Fellows
    Also, everything that is out, is out by the same value as the opposite side apart from the rear camber.
    Given that it doesn't seem there's much to be done and its not too terrible I may just try to forget it. At least they didn't charge me for it!
    Posted 10th Jan 2014 at 15:59
    allanallen
    It'd help if you let us know the values?
    Front camber should be around -.3 on a standard ride height car
    Facebook
    Posted 10th Jan 2014 at 20:30
    Fellows
    Good point... The values were:
    Front:
    Castor L: 2.37 Castor R: 2.27
    Camber L: -0.32 Camber R: -0.02
    Toe L: 0.22 Toe R: 0.18
    Rear:
    Camber L: -1.43 Castor R: -0.54
    Toe L: -0.02 Toe R: 0.01
    Is there any adjustment I have missed, or is toe the only one available as standard?
    Posted 10th Jan 2014 at 21:15
    jord294
    Have you mis worded the results for rear?
    Posted 10th Jan 2014 at 21:20
    Fellows
    I don't think so. The rear camber was the one slightly disturbing result that I thought looked pretty bad...
    Posted 11th Jan 2014 at 06:53
    jord294
    So you mean rear camber R : -0.54?
    Posted 11th Jan 2014 at 08:09
    Fellows
    I will double check when I get home this evening, but I think I copied it down right?
    What values would you expect for this?
    Posted 11th Jan 2014 at 09:05
    Lots more rear camber on the nearside then. Fooked beam?
    Posted 11th Jan 2014 at 16:38
    jord294
    My thoughts exactly
    Posted 11th Jan 2014 at 16:53
    Fellows
    Are the front values ones of any great concern do people think? I don't think I'll be replacing the whole suspension setup on what was a £500 car!
    Posted 11th Jan 2014 at 17:36
    Fellows
    All the values were copied right, I've just double checked.
    So, it seems the beam is less than straight. Assuming I can get hold of a decent one that brings the camber in (and maybe the toe if I'm lucky), would there be any problem running this car?
    The front toe can be adjusted so hopefully I would only be left with the front castor being a little out. Would this be a big problem? I'm hoping to use this as my daily in the near future.
    Thanks
    Posted 11th Jan 2014 at 18:34
    Did you check the tyre pressures first?
    Posted 19th Jan 2014 at 10:57
    xav
    id leave the front camber as it is. itll pull the car away from the kerbs on cambered roads. doe it feel like its pulling to one side or wearing tyres?
    did ye aye?
    Ex Spoox/Trac Prep GTi6 16v turbo - the money pit
    Posted 19th Jan 2014 at 22:55
