| Author | Subject: positive battery connector |
martinh
Seasoned Pro Location: Bideford Registered: 08 Dec 2006 Posts: 1,274 Status: Offline |
Does anyone know if anywhere other than Peugeot sell the the threaded part that pushes over the positive battery terminal? Or what they're called? Have tried searching with a few different terms but no luck! Mine has only got a few teeth left and would like to replace it! Cheers |
eBay |
martinh
Thanks mate. Have searched ebay but didnt find that! Will order a couple I think! Such a poxy design! ! |
Swap it for a later design ? |
martinh
There's a later design? ! |
scotzman
Seasoned Pro Location: Dundee Registered: 24 Jun 2011 Posts: 1,408 Status: Offline |
That ebay listing is for a -ve terminal, they are smaller than the +ve________________________________________ '90 1.6 205 GTi, '98 306 GTi-6 |
martinh
scotzman wrote: That ebay listing is for a -ve terminal, they are smaller than the +ve Good point! I only looked at the picture!! |
martinh wrote: There's a later design? ! Later design is a clamp. Personally I prefer the screw on ones. ________________________________________ ![]() |
stan_306gti6
dangti6 wrote: martinh wrote: There's a later design? ! Later design is a clamp. Personally I prefer the screw on ones. I agree. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
rikky
i hate them and have always put normal ones back onhow about that ________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
jimmyhackers
Seasoned Pro Location: birmingham Registered: 14 Jun 2011 Posts: 1,302 Status: Offline |
hm..... im afraid i agree with rikky.half of the peugeot specific things make life awkward and stressfull. id also mention i managed to remove about a foot of wire from the original battery loom. on a stanny car it doesnt help but if youve relocated your battery every cm of wire counts. ________________________________________ the world is changed by people in sheds |
6waysforward
Seasoned Pro Location: Benfleet essex Registered: 30 Oct 2005 Posts: 3,168 Status: Offline |
The threaded castle battery connectors always corrode and break up. I ditched mine on my old ph2.The clamp on the later cars is also very s**t. Again i cut them off and replaced them with some from my local motor factors for less than a tenner. Job jobbed ________________________________________ ***Breaking*** Ph3 Silver GTI 6 High Boost![]() |
stan_306gti6
The threaded castle connector doesn't corrode if you look after it and not drive the car in salty weather.However, if it's an all year round vehicle then I can see why that might happen, try some anti corrosion grease on it for those which still have the connector fitted. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
6waysforward wrote: The clamp on the later cars is also very s**t. Mustv'e got a s**t one never had a problem on mine. ________________________________________ Black X Reg PIII.VGTi 6 A4212 pt 1 A4212 pt 2 Searching the streets of Bristol for 1.36p/day.Joint Kent Leader |
Never had a prob with the later type either ? Plus it's easier To change the battery |
6waysforward
stan_306gti6 wrote: The threaded castle connector doesn't corrode if you look after it and not drive the car in salty weather. Erm.... i live by the sea mate ![]() ________________________________________ ***Breaking*** Ph3 Silver GTI 6 High Boost![]() |
stan_306gti6
6waysforward wrote: stan_306gti6 wrote: The threaded castle connector doesn't corrode if you look after it and not drive the car in salty weather. Erm.... i live by the sea mate ![]() Ah yes, of course you do. ![]() (Note to self: Never buy 6waysforward's car, it'll be rotten as hell... )________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
6waysforward
Tis ok, it's immaculate underneath and under the sill's. Oh and i wont sell it. Keeping it for a sunday drive in 40 years time with my flat cap and pipe. Thats if its not rusted away by then anyways. ________________________________________ ***Breaking*** Ph3 Silver GTI 6 High Boost![]() |
mattgti6phase2
Seasoned Pro Location: inside my 6 abusing the tarmac!! Registered: 16 Jul 2010 Posts: 2,371 Status: Offline |
So following on from this i have recently discovered my neutral cable has seen better days (the end connecting on to the gear box) i will replace the cable that also connects from the gear box (smaller cable) to the chassis leg. Does anyone know the thicknesses of these 2 cables and where i can get a connector (terminal end) and connectors for the gear box and chassis leg also? Many thanks Matt. ________________________________________ Team Nile 6![]() Team: 40.2 MPG ![]() 5 x a 306 owner! currently abusing type r's in a town near you ™ ![]() I truely live for the 306 ® Build date: 29th October 1997 Wednesday's car midweek madness |
I've a used negative cable Matt if it's of interest?________________________________________ ![]() |
mattgti6phase2
How used is used? I don't want the same troubles a year or so down the line sir. ________________________________________ Team Nile 6![]() Team: 40.2 MPG ![]() 5 x a 306 owner! currently abusing type r's in a town near you ™ ![]() I truely live for the 306 ® Build date: 29th October 1997 Wednesday's car midweek madness |
I'll get a cable whisperer to question how many times it's been undone.![]() I'll get a picture for you ________________________________________ ![]() |
mattgti6phase2
you know what i mean. ________________________________________ Team Nile 6![]() Team: 40.2 MPG ![]() 5 x a 306 owner! currently abusing type r's in a town near you ™ ![]() I truely live for the 306 ® Build date: 29th October 1997 Wednesday's car midweek madness |
