Author Subject: all three brake lights not working
astor gray 2014
Hi all 3 brake lights not working on my 306 rallye any ideas bulbs changed relay changed but still not working
Posted 8th Jan 2014 at 22:33
Switch behind pedal is a good place to start Smile
  • Posted 8th Jan 2014 at 22:45
    jord294
    How about brake pedal switch ??
    astor gray 2014
    That was changed too might wiring under dash as might have been disconnected when dash was put back
    Posted 9th Jan 2014 at 01:10
    switch or dash loom earth in driver footwell
    Posted 9th Jan 2014 at 08:31
    astor gray 2014
    A cool i will check it out today thanks for help
    Posted 9th Jan 2014 at 08:39
    Disconnect the switch and see you have powered being supplied to it with the ignition on.
    If so, then the issue lies with the switch or further downstream from it towards the light units. Yes
    Posted 9th Jan 2014 at 09:26
    jimmyboycheck
    Fuse?
    Silver 6
    Posted 9th Jan 2014 at 11:42
    jimmyboycheck wrote:
    Fuse?
    He needs to see if he has power at the switch first, because if he has the fuse is fine.
    Posted 9th Jan 2014 at 12:06
    astor gray 2014
    There is power to switch is there earth wire and there relay
    Posted 9th Jan 2014 at 17:42
    I put a new switch on and left the old one in the car ? Is there an earth behind the rear quarter panels ?
    It's my old rallye by the way !
    Glad you got back to Ireland ok bud
    Posted 9th Jan 2014 at 17:53
    astor gray 2014
    Thats what i was looking for Will look for tomorrow ran a multimeter but no power to lighting wires yeah i was thinking that
    Posted 9th Jan 2014 at 19:01
    astor gray 2014
    Posted 9th Jan 2014 at 19:05
    astor gray 2014
    Still no luck but airbag light off just had to reconnect wire
    Posted 10th Jan 2014 at 20:40
    astor gray 2014
    THanks ricky will check that
    Posted 10th Jan 2014 at 20:41
    I'm pretty sure it's a wiring issue behind the dash after doing the heater matrix ? I pulled the dash forward to get to the matrix but left the the switch connected.
    Posted 10th Jan 2014 at 21:11
    astor gray 2014
    A cool ill have to check that tomorrow thanks
    Posted 11th Jan 2014 at 04:53
    astor gray 2014
    All sorted it was the fuse and the second switch did the abs so all Sorted
    Posted 11th Jan 2014 at 12:39
    Happy days glad it's all sorted. Might want to check reverse light switch as I think it needs sorting as well
    Posted 11th Jan 2014 at 13:51
    astor gray 2014
    A ok cool ill have a look next drive shaft seal and engine mounting near gearbox need something good hard rubber omp maybe ?
    Posted 11th Jan 2014 at 14:28
    Glad it was a simple fix. Cool
    Posted 11th Jan 2014 at 19:30
